Engine Bay
I've been restoring this 68 convertible for 7 years now. I'm in the engine bay at this point. I've sanded the complete bay. It was black as expected but umder the black was the original body color (Corvette Bronze). Anyway I need advice on the steps and materials to repaint. Do I need to use a polyester primer, sealer primer and than paint? All in put is appreciated. The engine bay again is sanded and scuffed up. I did manage to expose fiberglass in various spots. No way to avoid that.
Thanks, Peter |
A lot of it depends on how nice you want it to look.
YES...you can go in and apply a polyester primer and then sand it so you can seal it and then paint it. OR...you can go in and apply PPG black epoxy primer and then paint on it. The possibility to very little to no sanding may be needed. The PPG epoxy primer DP90LV can be lightly sanded on and if the roughness in your exposed fiberglass areas. You can get it to fill those areas in.by applying more on it. AS you will see in the information below. The 'window' of time that the PPG epoxy primer can allow paint to be applied on it is quite long as how I read it but you can confirm this by calling them. https://www.nedsautobodysupply.com/P...er_1_11_1_.pdf The PPG DP90LF really does not like to be sanded on and it more of a 'wet-on-wet' type of primer so-to-speak. At the bottom of the information I provided is the 1-800 phone number to PPG and if you have specific questions. I would call them so IF the information provided does not make sense or you have questions that are not being answered in that information. CALL THEM and ask. What is odd about this information from PPG is that back in the day they used to put how many mils of product you were wanting to try to achieve. For some reason it is NOT in this information bulletin. DUB |
Originally Posted by DUB
(Post 1598430381)
It is hard for me to actually tell you what way to do it. Simply because IF you shoot the polyester primer all wrong and mess it up and you have dry spray and bad texture...then sanding out all of your 'nooks and crannies' can be a ROYAL PAIN in the backside. Knowing you want it he BEST it can be...but making the right choice and using that product to the best it can be used can allow you to achieve the end result you want. Hopefully that made sense.
The same holds true to if you used gelcoat or even epoxy primer. It will depend on how you apply it and if you can figure out how to apply a specific product that you can adjust it to get it to lay down SLICK and make the next step EASIER on you. I can do it any way we have mentioned BUT I also know that when I am prepping the firewall I will look at it carefully and over the years I know what to use or how to adjust a product to get it to work for me so I am saving time and aggravation. Gelcoat, polyester primer and even the epoxy primer can work... and I bet if you did three different firewalls with these different products...the end result can come out looking darn near the same...but the time and effort invested may be totally different....due to how these products were applied. DUB |
Boy Dub, you keep my head spinning. I thank you for that. So on a 1968, bare fiberglass, are you saying that epoxy primer can be used? I was under the impression that FRP (1968) we use Polyester. Can you set me straight on this. As a note, any bare spots in the engine bay are smooth and not frayed. With a bit of test, I am confident I will be able to adjust the materials to work for me.
Thank you again for all you input. |
Sorry that I get your head spinning but there are variables that are unknown to me that makes this not just a simple one answer reply to the question you are asking about. I know I could say shoot polyester primer on it and know you are going to work your backside off to get it right and move on to the next thread that catches my eye. But I am not like that and there are options as like I previously stated.
Epoxy primer can be applied on any type of bare fiberglass body panel GM made. And some polyester primers can be applied on top of epoxy primer because I do it that way when needed. We are talking about a firewall. Which I do not discount as being an important area of the car that a person wants to look good BUT it is not the same as that of the exterior which gets much more abuse from environmental things such as weather and the sun and rain and stuff like that. And if you have an issue on the firewall it is not as bad as that as a huge bubble in the center of your hood. SO..I GENERALLY DO NOT use epoxy primer on the exterior of your car. I use gelcoat as my first layer. Keeping in mind I am referring ONLY to a polyester body panel and NOT an SMC body panel where I DO use epoxy primer. Because I DO NOT gelcoat on top of SMC. So...if you wanted your firewall PERFECT where there is absolutely NO texture and your sand and buff it out to make it look like it was dipped in baby oil like you see on some the the cars at a SEMA show where they can spend hundreds of hours on the firewall. THEN I would take another route due to wanting the end result to be absolute perfection and NOT ONE glitch anywhere. BUT ONCE AGAIN...it all depends on how the fiberglass is on the firewall. Because I can still make it look like a car ready for SEMA and not have to take the most extreme method to get it to look that way. Keeping in mind also that this is not a trailer queen but the car is going to be enjoyed and driven...which DOES take it to another level due to it will possibly see some effects from the engine running and heat from it and so on so PREP is still PARAMOUNT for maximum adhesion. Keep in mind that HOPEFULLY you are applying a semi gloss or satin black paint due to IF you go GLOSSY black paint...or clear over it.. It will show up EVERY imperfection you may have in it...including any small specs of lint that lay on the surface. Hopefully your head has stopped spinning.....because you CAN do as you initially thought and that is to apply polyester primer...sand it and then seal it and paint it. If your concerns IF the epoxy method is worth the effort to try out. KEEP IN MIND that ANY paint you still have on the firewall...can be an area where the chemicals or solvents in whatever you apply on it can cause it to wrinkle or lift up IF that initial coat being applied ON TOP OF IT is applied way too heavy or thick.. NOT saying that it WILL happen,...but it can happen. A slight lifting or wrinkling at the edges of any paint where it stops and then exposed bare fiberglass begins. The 'funny' thing here is you need to get it wet enough to allow whatever is in the product being applied to penetrate in and provide the possibly the chemical adhesion factor designed into that product ...so it does need to be slightly wet. But not soaking wet to the point where the solvents or chemicals in the product now are there and do to the volume of it. It can now penetrate more into whatever it is being applied on. USUALLY epoxy primer and polyester primers do not do this but it can happen if you go in and flood the panel with them. DUB |
Thank Dub. I will pick my approach and feed back the results.
I am confident your choice will work well for you and I am waiting to see how well you did on it.
DUB |
Firewall
Peter |
Keep in mind that I know you wrote that you have the entire area sanded...but in 'rvzio's' first photo you can see that the paint and primer were removed.
Like I previously wrote. even though the area has been sanded on...if leaving paint and primer on areas can possibly cause for an issue when you go and apply a product to it. I am not saying it all has to come off...but if it is not on the surface than it can not cause for an issue. DUB |
PPG k36 primer and Hot Rod Matte black. Didn't want it real shiny. When it's first applied it all most looks like a gloss. Once it cures it's perfect. I liked it because I could get a good touch up match with Krylon #1613 semi flat black just in case I needed to do that.................................... ...........
Sorry to jump in the middle ! |
No apologies needed here...it is all about providing useful information and photos to show what has been done and how it worked out.
DUB |
https://cimg8.ibsrv.net/gimg/www.cor...375d50090.jpeg
Originally Posted by rvzio
(Post 1598484070)
(Post 1598507047)
https://cimg9.ibsrv.net/gimg/www.cor...adf3dfff3a.jpg
Should have post a while ago. https://cimg8.ibsrv.net/gimg/www.cor...e874f3d116.jpg Wanted thank you guy for your input. This the final result. I can live with it. Plans are to marry the chassis with the body sometime this month. |
Looks like it came out very nice. You can see how much goes into making it a first class job. Don't forget the inner fenders when you get to that point.
:thumbs: RVZIO |
:iagree: Exceptional job!!!!!!!!!!
DUB |
