Gauge Cluster(s)
Found another box in my garage containing center gauge clusters:
1. Original gauge cluster from my '81, all were working including the clock when removed. I had added a new radio with a digital clock so I replaced the analog clock with a oil temp gauge, which required a bezel from an '82. It does not have the flex print circuit on the back (it is in the car). $150 plus shipping. 2. Oil temp gauge. $25 shipped 3. Speedo, $50, plus shipped Pictures are below:] https://cimg1.ibsrv.net/gimg/www.cor...b1846fa918.jpg https://cimg2.ibsrv.net/gimg/www.cor...c00735d167.jpg |
No one needs these???....really....
Originally Posted by LannyL81
(Post 1598458948)
I'm getting no bites either. Craig |
I'll bite. PM sent for the two unpopulated bezels.
Bikespace: yep, replied to.
Yeah I saw your gauges for sell as well. Correct me if wrong here, but the gauges are the same for 78-82 with the exception that in 82 the analog clock was replaced with an oil temp gauge due to the digital clock......or was that an option in 81?.....now I am not sure anymore, been too long.
As I said above I replaced the clock in my 81 as I installed the ETR radio/cass with the digital clock. I had both analog and digital clocks for awhile but it just did not look right so I bought a used set of gauges/bezel with the oil temp gauge and swapped it....that is why I have the complete set out of my 81...except for the flex print which I had to use. I used to have a spare flex print but think I sold it. Anyways, someone needs to buy these gauges. |
Ttt
Hi Lanny, I am only interested in the 81 clock, I presume, it's all original, not the quartz movement. Would you be okay to say goodbye just to this item? Thanks Tom
Vogast: sorry I just saw your reply today; yes clock is original, but would rather not separate it from the cluster.
Thanks |
(Post 1598620837)
Thanks |
I updated the list in the first posting of what I have left.
