441ci ERL shortblock with AllPro LS7 heads/intake Dailey billet oil pan
I built this motor for my road race gray RX-7; however I sold it this year with a 416ci setup inside instead. This was originally in Dave Kixmiller's 358ci destroked Bonneville salt flats record holder S10 pickup truck that my buddy Chris Coffey built/fabricated. Kurt Urban spec'd/built this engine with KixMiller Racing.
I purchased the engine with the original AllPro single plane intake and 2 fried pistons from nitrous use... and then overbored it... added the longer stroke crank/rods to gain 80 cubic inches. Reuse the heads/lifters/rockers also. https://www.lsxmag.com/features/inte...at-bonneville/ Here are the details on the motor: ERL Superdeck1 (4 bolt head style) Darton resleeved alum 5.3 orginally built spec'd by Kurt Urban. Darton sleeves are 3x stronger than the factory liner. 4.190" bore (can go to 4.200" bore) billet main caps, ARP main studs, Katech piston squirters, bronze bushed lifter bores. This was $5K alone. Was sent back to ERL for inspection/cleaning then over to me. LS7 crank (std/std) with cut snout for wet sump oiling (or aftermarket dry sump) LS7 Titanium rods rebushed with Katech bushings, ARP 2000 bolts RaceTech 13:1 forged pistons for n/a use Calico coated bearings throughout AllPro LS7 58cc castings ported by WCCH (428cfm), Ti 2.20" intake valves, s/s exhaust, Jesel solid roller 1.7 rockers ($$$), custom valve covers with integrated rocker arm oilers (spray bars inside and -AN fitting up front) These were sent back to WCCH before I received them and refreshed. I opted for PAC 1209X .750" dual springs with Ti retainers which are affordable if they ever need to be replaced. AllPro ported LS7 single plane aluminun intake by WCCH, new Bosch 80lb injectors (for e85), AllPro billet rails, AccuFab black 4500 style throttlebody (cable driven) with IAC and TPS ARP head studs, your choice of head gaskets Cammotion solid roller 252/260 .714" lift cam, Jesel link bar lifters ($$$), pushrods still need to be purchased but included your choice of Melling oil pump, C5-R timing chain (for wet sump oiling) includes front/rear covers KUP (Kurt Urban Performance) distributor belt driven front cover conversion with ICE coil, wires, spare coil, MSD amplifier box included ($1500+) for high RPM (was run with the carbureted setup in the link to 9500rpm). Currently in shortblock form.... would entertain selling shortblock without heads/rockers/intake setup for $9K. The work to the bare block alone was $5K from ERL and no internals. If you put on LS7 heads it would drop compression down to around 12:1 due to larger combustion chamber. The crankshaft snout has been cut and is not the OEM style dry sump long snout. When I spoke with Kip at Cammotion to grind the cam I wanted the power to come on around 3500rpm and carry to 7500rpm and not fall off ...... so if you wanted to rev it to 8000rpm you could and not have to upshift into a corner (road racing). He felt it should make around 800hp flywheel with the above combo on 13:1 running e85. your choice of ATI balancer $20K shipped to the lower 48 states with AllPro heads/intake etc. no oil pan. This can easily be made into a dry sump engine with an aftermarket dry sump setup... ie ARE, Aviad, etc. |
Some interest.... but it isn't going under anybody's tree just yet!
Still time for Santa to deliver it tonight :)
Happy New Years!
To the top!
PM's replied to
Just picked up a Dailey billet oil pan to clear the 4" stroke and is designed for a C5/6 application. Add $3000 if you want it which includes a Peterson 3 gallon oil tank with a bung welded for electric oil heater (includes 110V heater insert), adj pressure regulator, belt, breather tank. Only thing required is to make the lines/fittings upon install. I don't want to sell this setup until the engine sells.
Dailey dry sump setup is brand new.... Peterson tank/breather are used. |
https://cimg9.ibsrv.net/gimg/www.cor...ac68e3d148.jpg
https://cimg6.ibsrv.net/gimg/www.cor...a833ee1299.jpg https://cimg0.ibsrv.net/gimg/www.cor...4c30de69ac.jpg Some pics of the shortblock. Will take some pics of the heads/rocker arms this week |
https://cimg6.ibsrv.net/gimg/www.cor...2dfa40b6d9.jpg
https://cimg1.ibsrv.net/gimg/www.cor...db7bc078c3.jpg https://cimg3.ibsrv.net/gimg/www.cor...ce42a0f19b.jpg https://cimg7.ibsrv.net/gimg/www.cor...082e0f0bfb.jpg Dailey Billet production style pan 3 stage. Everything pictured is included. The 2nd pulley is for an Fbody application. |
To the top!
to the top!
to the top
to the top
bump it up!
To the top
to the top :)
You selling the Dailey set up?
It is tentatively sold.... to a guy in Canada.
to the top. Guy flaked on buying the dry sump parts
To the top!
