heater/ac blower rumbling noise ?
I have a '97' , when I turn on the heater fan, I get a screeching sound that comes and go's... it's fine when the screeching sound go's away...but what's up with that ?
Moved to C5 Tech. |
The bearings in the fan motor are most likely going bad. The motor is easy to replace and not too expensive. Some people have had luck just using some oil on the bearings but eventually it will need to be replaced.
Originally Posted by BigGun
(Post 1598446356)
thanks,... I guess a new blower motor is in order given the age and history...
Regardless, the job is pretty easy but beware, it's back-breaking
Originally Posted by turabo87
(Post 1598449812)
Blower motor is only 3 bolts and a connector. If you're not a really big person it is not that bad.
