441 RHS All Pro Head 6 Bolt LS7 Engine Longblock Dry Sump 13.5:1
SOLD!!! Fresh from the machine shop (Baldwin Racing Engines), never ran. Setup for 300+ shot of nitrous and 13.5:1 Compression. Changed plans and car was put back to stock to concentrate on my c7. I have well over $20,000 in this long block with machine work and assembling. I will take $12,000. New RHS Block Used Compstar Dry Sump LS7 Crank New Molnar Power Adder Billet Rods New CP Custom Pistons New Custom Billet Solid Roller Cam also have a Custom Lil John Nitrous Hydraulic cam with idle time only I can include. Morel Black Momba Solid Roller Lifters All Pro 12-1 Heads (Used but have all new valves, etc) PSI Springs T&D Rockers 1.8 New ATI Balancer RHS 6 Bolt Head Studs Comp Pushrods Custom Fabricated Holley Tall Valve Covers with -10 bungs welded on (included but not in pics) LS7 Oil Pan and Windage Tray Shimmed LS7 Oil Pump Modified LS7 Timing Cover for raised cam All new bearings, head gaskets, oil pan gasket, etc. https://cimg7.ibsrv.net/gimg/www.cor...a56a0dc9db.jpg https://cimg5.ibsrv.net/gimg/www.cor...ed8daeb0f1.jpg https://cimg8.ibsrv.net/gimg/www.cor...6f2885320a.jpg https://cimg8.ibsrv.net/gimg/www.cor...0bbbcc7e9d.jpg https://cimg1.ibsrv.net/gimg/www.cor...a8359f5369.jpg https://cimg1.ibsrv.net/gimg/www.cor...7920f68e92.jpg |
Bump
Bump |
What are the specs on the cam?
Originally Posted by Turbo2L
(Post 1598633014)
Bump
Bump
Arrrghhh if only I had the funds
