Asr
I own a 1995 C4 Corvette that I have rebuilt everything throughout the entire vehicle except for the paint. Today I went to start the vehicle and got three warning lights. The ARS, ARS OFF and ANTILOCK BRAKE lightsl were on. Has anyone else experienced this? I ran A complete diagnostic and got no codes. I am confused. What should I do now?
Check the brake fluid level first. Having low fluid will trigger those lights.
Yup. Adding the slightest amount will make the lights go away.
drive the car for a little. my old 94 would have those lights come on if I had it jacked up a certain way. then I would drive it and it would go off
For a few weeks, mine would come on under hard acceleration. It wouldn't go off until the car was turned off and turned back on. Stopped doing it on it's own.
Originally Posted by ChumpVette
(Post 1598444653)
ASR light
Originally Posted by c4cruiser
(Post 1598453949)
Sometimes even adding fluid to the FILL line isn't enough for the lights to turn off. Fill the reservoir as close to the top of the reservoir lid as you can. The fill line usually is about 1/4" to 3/8" from the top and if the fluid gets moved around from hard acceleration or cornering, the sensor will pick up the lack of fluid and turn the lights on.
I checked the brake fluid and found it to be really dark, almost a coffee color. Will replacing the fluid thoughout the system help? |
have the same issue on my 96 . will have the ground points cleaned while the car is in the shop next week for it's 5 ! booster . such fun .....
Originally Posted by johno504
(Post 1598470032)
I changed out the booster and master cylinder this past Summer. Everything was working fine until we got our first freeze. A day later I started the car and the ADR light came on. As soon as I drive about 50 feet, the ABS service light comes on. |
Make sure the battery is fully charged.
ASR light
Originally Posted by 383vett
(Post 1598471000)
New battery reading 14.5 volts. I am thinking that with the old brake fluid in the system, the fluid may have sludge that reacted to the cold weather. Will replace the brake once the weather lighten up. Will let you know when I'm done. |
C4 asr
Once I realized the ABS pump was not priming when I turned the key on, I knew the problem was the pump. Changed out the pump and all is well with my Vette.
Thanks for all the help. |
What all is involved in changing pump
Originally Posted by Tx_94vette
(Post 1598641705)
Once the new pump is installed, turn on the key and bleed one line at a time. Make sure you place a towel in the compartment before you begin. |
