-   C7 Tech/Performance (https://www.corvetteforum.com/forums/c7-tech-performance-169/)
-   -   Stingray power/speed limiter? (https://www.corvetteforum.com/forums/c7-tech-performance/4219342-stingray-power-speed-limiter.html)
Mensan150 12-05-2018 02:48 PM
On a basic C7 Stingray without the Z51 option, is there any kind of speed/power limiter in the various modes - especially sport and track? If you went out on a deserted straight highway to run it at high speed, what would be the best mode option to get maximum power and speed?
eboggs_jkvl 12-05-2018 03:55 PM
Well, you have an RPM limiter and a speed limiter. Whichever you hit first would be your top speed. A manual transmission would be in 5th gear. THe Automatic might be in 5th gear too, dunno for sure. Sport or track won't matter.
Elmer
vader86 12-05-2018 05:22 PM
Is the RPM limiter a fuel cutoff or actual rev limiter?
eboggs_jkvl 12-05-2018 06:48 PM
Fuel cut-off
MrHix 12-05-2018 07:19 PM
What about the Performance Traction Management modes? It looks like power is reduced in modes 1 - 4.
These things are so complicated . . . . .
Cheers,
MrHix
Fast6.3 12-05-2018 09:41 PM
You can disable the speed limiter
Avanti 12-06-2018 04:52 PM
It is called "drag limited." All the best. ::lol:
Mensan150 12-07-2018 09:42 AM
Cheers,
MrHix
Is this available on the basic Stingray? I have the five basic mode choices, but I'm not aware of what you're referring to.
MrHix 12-07-2018 09:53 AM
According to the owners manual "Performance Traction Management (ZR1, Z06, Grand Sport, and Stingray with FE4)." FE4 = Magnetic Ride Control, I think.
Cheers,
MrHix
WhiteGS 10-07-2019 09:31 PM
how can I disable it? Please let me know.
I recently went with coilovers with mag delete kit. And this started happening afterwards.
Weirdly when I get a “service suspension “ notification on my dash. That’s usually when the speed limiter happens and doesn’t allow me to pass 85mph
eboggs_jkvl 10-08-2019 12:54 AM
You would need to edit the tune to disable the speed limiter. Of course, that edit would negate your drive train warranty.
Elmer
subieworx 10-08-2019 12:36 PM
Maybe fix the problem with the suspension first instead of trying to fix the result.
