-   C1 & C2 Corvettes (https://www.corvetteforum.com/forums/c1-and-c2-corvettes-4/)
-   -   c1 carpet (https://www.corvetteforum.com/forums/c1-and-c2-corvettes/4219347-c1-carpet.html)
SRC60 12-05-2018 03:04 PM
c1 carpet
Does anyone make C1 carpet without the shifter hole cut in the carpet? I have a 1960 Corvette with a 6-speed transmission and the shifter is mounted in the middle of the tunnel and further back than the stock shifter. All the carpet sets I've been able to see have the stock shifter location already cut in the carpet.
Any help would be appreciated.
Thanks, Steve
Frankie the Fink 12-05-2018 03:50 PM
1 Attachment(s)
Al Knoch carpet does not have the shifter hole cut as you can see in this document I put together on installing carpet in my '61....
Frankie the Fink 12-05-2018 03:54 PM
1 Attachment(s)
If you call Al Knoch I'm sure they will arrange to sell you carpet that does not have the shifter hole cut...
I attached some installation tips...
59BlueSilver 12-05-2018 10:56 PM
Mine came from ACC, as a lot of them do, and it didn't have the shifter hole.
https://cimg9.ibsrv.net/gimg/www.cor...30b377f493.jpg
SRC60 12-06-2018 10:17 AM
OK, thanks for the info. I will check with them. My tunnel is also a bit larger just behind where the shifter is but I think I can work around that.
SRC60 12-06-2018 04:15 PM
I contacted ACC today and they said all there carpet for my 60 had the hole cut in the tunnel piece for the shifter.
68hemi 12-06-2018 05:08 PM
Yes but I am sure if you ask they will send you a carpet kit WITHOUT it being cut.
59BlueSilver 12-06-2018 11:38 PM
Must be something they just started doing. Installed mine about two years ago.
SRC60 12-07-2018 08:23 AM
When I called them yesterday they said all of the carpet sets for 1960's had the center hole cut in it. I asked if they could sell me one without the hole cut, they said no. I'm going to call Al Knock today and say what they say.
Steve
