65 Vent Glass Mounting Strips
After placing the mounting strips around the glass, I pushed the glass into the frame. For some reason it does not seem like that should be all that I should have done. Seems like the glass would slide out when the vent is open. Did I miss something or was it really this easy to do?
Thanks, Dex. |
I have installed these Dex. Should be a pretty snug fit.
Can you pull the glass back out by hand? If No, all is good. If Yes, there is an issue. Greg |
Originally Posted by Greg
(Post 1598451221)
Can you pull the glass back out by hand? If No, all is good. If Yes, there is an issue. Greg Thanks, Dex. |
Bingo!
:cheers: |
You will know if the vent window is seated completely in the frame when you go to close it it should fit in the opening perfectly if not it is not all the way back into the stainless steel frame. I use a rubber mallet with the stainless steel frame backed up with a piece of wood. Works every time. |
Originally Posted by 65 Pro Vette
(Post 1598455642)
You will know if the vent window is seated completely in the frame when you go to close it it should fit in the opening perfectly if not it is not all the way back into the stainless steel frame. I use a rubber mallet with the stainless steel frame backed up with a piece of wood. Works every time. Thanks, Dex. |
