how to install convertible pads for 1961 corvette?
how to install the pads and straps for convertible top for 1961 corvette.
You cannot install the pads separately. The whole top needs to be changed. |
Originally Posted by mike coletta
(Post 1598452465)
You need to get the spacing correct by first tackling the rear window area. I remember I worked forward from the header to the three rear braces. Then worked from the back window forward until I had the spacing correct for the two rear straps. So like placing the convertible top in place until I got it correct. Using string or something is good to use to get the bow spacing correct.
4VetteOwner....locate and get the Al Knoch video showing how to install a top on a C-1.:cheers: Dennis
