Time to re-power the race car.. New goals 280mph and 2000ish HP
After running 267 mph this year on my original F1x setup, I have decided to re-power and go for the overall Corvette speed record in 2019.
Long block is out and getting upgraded. New billet crank, o-ringed heads, etc. F1x and belt drive is out and being replaced. Not ordered yet, but I am leaning towards a 106mm single turbo up front. Car will retain the 2 stage direct port just in case! I am thinking of running the inlet piping thru the front bumper again, air-to-water up front, radiator out back. Staying with the manual trans for now, but we will see how it takes the power. A few small things to figure out, but it should be a fun winter getting everything put together. https://cimg3.ibsrv.net/gimg/www.cor...2f7311ba23.jpg https://cimg5.ibsrv.net/gimg/www.cor...72509a1f26.jpg |
WOW !!!! I'll be sure to follow this :thumbs:
Heck yeah go for it!!!!
Jesus. Should be insane. I gotta see this car sometime. Just moved to Portsmouth NH.
nice build! how do you like that lift?
F1x
What kind of power did the flx put down ?
Originally Posted by MTBSully
(Post 1598461255)
Long drive (6 hrs 1 way).. but a trip to Loring is well worth it! |
Originally Posted by C U IN REARVEIW
(Post 1598465289)
heck get some balls,300mph and 3,000hp
cars cool,please keep posting pics |
Originally Posted by Sncobra331
(Post 1598465544)
My best pass had some belt slip and only made 27psi and only took a 100 shot before the clutch slipped trying to spray the second 200 shot.. Car easily had 270 in it that day :D |
Originally Posted by dmaxx3500
(Post 1598466784)
Holy shit. This is going to be an awesome build. :cool: |
What fuel & pump system are you running?
Any thought to run M1? |
sub'd
Originally Posted by Capthuff
(Post 1598471767)
Any thought to run M1? I am eyeing the area where the mufflers reside for either the radiator ,or a square fuel cell. An off the shelf cell would make fuel pumps and plumbing much easier in the future. The Fore system I have is rated for 2000.. Not sure if we will try it or not :) |
I have an 8 gallon cell in the back and setting up the fuel line/pump is certainly a bit easier than dealing with OEM tanks.
I'm using a Waterman cable and rear mount pump with M1 and no I/C. But my car is only a drag car - 1/8 & occasionally 1/4 mile. No water in the block. You probably can't do that. |
Not much done this weekend.. A couple small projects while waiting on parts. Back to the real job tomorrow.
I did start a new battery box.. This new Miller Dynasty Tig is great at hiding the fact that my hands shake like a leaf in a hurricane! https://cimg4.ibsrv.net/gimg/www.cor...ffa96d5a23.jpg https://cimg2.ibsrv.net/gimg/www.cor...92d15853fd.jpg |
Dang, nice job!
(Post 1598472338)
:thumbs:
