my 1999 harmonic replacement and winter upgrades
Hi all, using this thread to track and share progress on my work on my car I'm going to be doing. Hope you can help and share some tips!
https://cimg9.ibsrv.net/gimg/www.cor...853cfc9e6c.jpg |
Im working on replacing the harmonic balancer and going to do the water pump now too. Front of cars up on stands.
Anyone know if I can replace these bushings or just get this whole part? I think they are called end links. https://cimg6.ibsrv.net/gimg/www.cor...913d6c3214.jpg I have the front of the car up on pucks rear tires sitting on a 2x10 and chocked. The extra jackstand is just in case and not loaded. https://cimg7.ibsrv.net/gimg/www.cor...f8e5f68d40.jpg Anyone borrowed a kit from auto zone to do this job? I believe I'll need 27139 and maybe 27144 will help with the install. https://cimg8.ibsrv.net/gimg/www.cor...dbae359839.jpg |
A standard three jaw puller works great on the damper. the installer is required, I made my own from a section of roll bar tubing, some flat bar, the bolt I took out, and a piece of acme thread all thread and a nut. welded the acme threaded rod to the bolt after removing the head, slide it through the tubing and crank it on. The OEM damper has little recesses to catch the three jaws of a three jaw puller.
Those sway bar end links, but the Moog all metal ones, much better. Get four, do the rears too. |
Auto or Stick? You have to lock the flywheel on an auto. This means that you have to drop the exhaust down and move the starter over to get the Flywheel lock in place. You Do Not have to take the wires off of the starter. To get the rack out, you have to drop the cradle down about 5/8 of an inch to get the rack head out. Make sure that your jack stands are under the front pucks on the rocker panel. O2 sensor wires on the exhaust are long enough to just drop the exhaust down on the floor and slide it out of the way.. Most important thing on this project is to bungee cord the steering wheel straight ahead so that it cant move. If it accidently spins on you..........well, you dont want to know. Harmonic ballancer bolt is 240 foot lbs. Use a 3/4 drive ratchet with a 3 foot cheater pipe on it. 6 point impact socket only. Put in a new front seal also. I think that the 6 point impact socket was 15\16ths. A good replacement balancer is the Powerbond/Dayco PB1117SS Race. $250 dollors from Summit or Jegs. Hope these tips help you. Mine is a 1998. Good Luck.
I used a method to hold my balancer that does not require removing the starter. I used my old belt to hold the crankshaft from turning. As stated above you have to lower the front cradle a small amount to be able to get clearance for the steering rack out of the way. I supported my car at the four jacking points rather than on the front cradle as you have you car supported now.
Here is a link to the method: https://www.corvetteforum.com/forums...ving-bolt.html |
Originally Posted by zachaeous
(Post 1598484591)
Here is a link to the method: https://www.corvetteforum.com/forums/c5-tech/2099881-great-way-to-hold-balancer-while-removing-bolt.html |
Hi guys the rack is out. This is a manual transmission car.
You can replace those sway bar end links with inexpensive Moog units. Be sure to get the metal bodied ones (not plastic!)
Originally Posted by captaingeek
(Post 1598483600)
https://cimg3.ibsrv.net/gimg/www.cor...fd9b1d1228.jpg front of car up on stands |
Originally Posted by tabbruzz
(Post 1598494957)
I am doing the same winter project...not looking forward to it personally..did you just unbolt the ebcm and push it up a bit?
Steering racks out! Should have pulled balancer tonight but was lazy.
:sleep: |
(Post 1598498619)
correct. I've heard you can push it up a set of bolt holes but I didn't do that.
I got the rack and pulley bolt out. measured the crank end to pulley at 3.26mm.
I think I may have pushed the tie rods in a bit during removal. also, I dont have the steering wheel bungied as I saw some others do. |
(Post 1598569299)
https://cimg0.ibsrv.net/gimg/www.cor...2f2c7330c0.jpg
https://cimg2.ibsrv.net/gimg/www.cor...30fb7630c7.jpg
(Post 1598569299)
My Racks back bolted in, as of this morning. Here's some pics:
https://cimg6.ibsrv.net/gimg/www.cor...585729aa26.jpg https://cimg0.ibsrv.net/gimg/www.cor...bc19f39419.jpg https://cimg8.ibsrv.net/gimg/www.cor...77e6be6166.jpg https://cimg2.ibsrv.net/gimg/www.cor...f5a55fbb55.jpg https://cimg1.ibsrv.net/gimg/www.cor...2b43fcc1c0.jpg https://cimg9.ibsrv.net/gimg/www.cor...c09788417d.jpg |
Nice
Stubborn balacer
Have been working on this project this week. Went well until it came time to remove balancer. So far I have broken 2 generic 3 jaw gear pullers. I have a 3 jaw balancer puller on the way from EBay. None of the local auto parts stores in Northern Michigan carry them in stock. Have heated with heat gun and soaked several times with penetrant. Is there anything else that I should be doing to make it come off easier? |
Originally Posted by Bubba1951
(Post 1598725497)
Have been working on this project this week. Went well until it came time to remove balancer. So far I have broken 2 generic 3 jaw gear pullers. I have a 3 jaw balancer puller on the way from EBay. None of the local auto parts stores in Northern Michigan carry them in stock. Have heated with heat gun and soaked several times with penetrant. Is there anything else that I should be doing to make it come off easier? you will have to remove the puller so you can unscrew the crank bolt a bit so you can pull it further...you should only do this a couple of times as you will lose thread count each time you loosen it...at this point you can use another bolt with a small head so the balancer hub can pass by it....I used a bolt that came with my crank pinning kit.... |
(Post 1598725497)
