persistent spark plug fouling
Im having problems with my spark plugs.Ill start with what my engine is first. I have a Blueprint 355 engine with Edelbrock manifold and 650 carb. I have a DUI distributor with MSD wires. Everything is new. Im using Champion 792 with .045" gap(which is what they suggest using). Car runs kind of rough and has poor throttle response. I then tried to start again but wont because the plugs are wet and fouled.I tried tuning the carb so it wouldnt run so rich but i still get a rich condition. Any help would be greatly appreciated. PS. I tried to search this forum but could find anything.
two things come to mind, float level too high and why are you running such a cold plug? A 792 is a C59YC. The heat range of 59 is recommended by Champion for engines with a 13.0:1 to 14.5.0:1 compression, see page 5 and 6 below.
https://www.gsparkplug.com/media/wys...ence_Chart.pdf |
I believe that’s a cold heat range racing plug. Probably need a hotter plug to burn off the deposits for everyday driving. |
Blueprint engines recommends these plugs and used them at the dyno, Also my compression is 10 to 1
Iv tried other plugs that where in the hotter ranges at no avail. I bought a 7lb mech fuel pump,do you think i should use a fuel pressure reg? should I try diff. needle sizes in cab? Is carb to big?
Which pump? STock needle/seat size is fine.
Use a stock heat range spark plug, try that first bet it solves your problem. 650 is the perfect size for what you got. |
Originally Posted by Japery
(Post 1598509953)
Take the air cleaner off and look down the carb with engine running. Do you see fuel dripping/pouring down?
(Post 1598510220)
Did you measure the fuel pressure, Edelbrock carb has a maximum of 6.5 psi? Did you set the timing to what Blueprint recommends, 34 at 3,500 rpm? |
I bought the 7lb summit racing fuel pump for a 350 CSB
The car is at the mechanics and he cant really pinpoint what the issue is either. Ill check that on monday. Thank you
Which 650 do you have? Post #8 gave me an idea common to Holleys.
I think my first step should be to install a pressure gauge and see whats going on before the carb. Thoughts?
edelbrock AVS2 series
Ok, never mind. I really doubt this is a sparkplug heat range issue right now. You are flooding. And no certain sparkplug is going to help you.
Why are you flooding? IDK Raw fuel is entering unmetered some how, somewhere, some place. Just a few drip-drip-drips from the boosters or shooters will screw up everything. Good Luck |
(Post 1598510505)
I agree...sounds like a carb issue. Need to fix that first. No way you should be fouling plugs.
That said...does it smoke? Can you post pics of plugs? Is there oil getting on them or just fuel fouled? JIM |
https://cimg2.ibsrv.net/gimg/www.cor...d2b633577.jpeg
these are the hotter plugs. Autolite AR3910 |
I dont see any oil. some seem dry and others are wet with fuel. black smoke out of side pipes but not to bad
I agree, I tend to thing it's the carb leaking or just too rich.
I had an issue last summer with dirt in the carb - kept the float from seating the valve and it dripped fuel into the carb... |
