Plug & Play LED Headlights
Does anyone have any experience with Headlight Experts LED headlights?
These seem to be the ones for my 74 vert. https://www.headlightexperts.com/car...orvette-444533 They are suppose to be plug and play without having to cut the bowl. Any suggestions for similar? I'm not into cutting anything. Thanks |
Does anyone know of ANY plug and play LED headlights for a C3? Most require cutting the bowl behind the lights. I'm looking for a simpler way to swap to brighter headlights.
Originally Posted by nykbob
(Post 1598671397)
Originally Posted by Big2Bird
(Post 1598671449)
Have you installed headlight relays yet? It makes a significant difference.
(Post 1598671397)
I strongly recommend the headlight relay harness upgrade, plus halogen sealed beams. Unfortunately, there are no recent redesigned sealed beams (like the GE NightHawks) for the small round form factors.
If you want a better pattern, go Euro (aka ECE, or E-code) lights (H4 high/low outers or H1 low only outers, H1 high only inners). If you want to blind yourself and traffic around you with excessive glare, go LED. None of the LED "bulbs" and very few of the LED Sealed beams are legal or safe for use on public roads. I've witnessed a couple of single car accidents from people who couldn't see obstacles with their extra bright "LED retrofits." One of those accidents, I rode the passenger seat of the car into a downed tree. |
(Post 1598671449)
Originally Posted by How Are You
(Post 1598673557)
Is there a write up on how to do this? :cheers:
BTW, Daniel Stern is a good source for relay kits. Corvette (C3) specific threads here: https://www.corvetteforum.com/forums...ays-again.html https://www.corvetteforum.com/forums...-question.html There are more, but those two have wiring diagrams, information. |
Good info! there are some led headlights that have a projector fitted so the beam has a distinct cut off like how a factory equipped vehicle would. That being said, I don't know if there are any in the C3 size that have the projector in the led headlight.
