Corvette Camaro Tuner in Tampa
Check out my website -->> www.TampaTuning.com
Tampa Tuning is the home for street performance tuning starting at $325 Corvettes and Camaros at the stock to bolt ons level. My street tuning process takes several hours to complete. Its the best way to collect scanner data for low end drivability, cruising, and WOT under actual load and airflow of the vehicle. My HP Tuners interface has unlimited credits for LS1, LS2, LS3, LS6, LS7, LSA, LS9, L99 engines :thumbs: C7, Gen6 Camaros, and trucks are $100 more. Great modification for the buck! Corvette Camaro Tuner in Tampa Instagram : TampaTuning OUR TOTAL STREET PERFORMANCE TUNING PACKAGE FOR GM LS1-7 VEHICLES IS $325.00 WITH TRANSMISSION PACKAGE INCLUDES: www.TampaTuning.com Read and reprogram your PCMs settings and perform real time scanning diagnostics for the best results Increase power enrichment rate mode Examine and change timing tables for additional horsepower & torque gain Optimize your vehicles Air and Fuel Ratio monitored by the NGK/ AFX wideband unit Reduction of intake air temperature table (heat soak) Desired rev limiter adjustments Park, neutral, and in- gear idle adjustments with and without A/C active Adjust power enrichment delay to immediate Engine torque management system reduced Transmission torque management system reduced Transmission shift points enhanced Transmission shift times reduced Transmission shift pressure firmness enhanced if needed Skip shift deleted (CAGs 1st to 4th ) Fuel injector rescaling for aftermarket injectors if needed Cooling fan activation temperature and percentage of cooling recalculated Perform speedometer re-calibration for rear gear ratio and tire size change Turn off check engine light and remove trouble codes www.TampaTuning.com Phil |
Corvette tuner in Tampa
Weekend bump
Email: Tuning@TampaTuning.com www.TampaTuning.com Instragram: TampaTuning
Originally Posted by Tampa Tuning
(Post 1598576412)
Corvette Camaro tuner in Tampa E85
Florida racing weather is upon us. If you want to go faster, reach out for www.TampaTuning.com
(Post 1598576412)
