Just got my Range AFM
Hey all those with a Range device. Just got mine and looking forward to trying it out soon. Any input from the gallery or hints would be great!
Hoping for a smoother A8! As my tranny is okay except when going in and out of V4. Very annoying! Happy New Year all vette fillies |
Just plug it in and enjoy ..
Dave |
Just plug it in and go. In the beginning I unplugged it when I got out of the car fearing battery drain. That is not an issue so it stays plugged in and the car shifts and runs great. This is an awesome mod for sure. You should love it. |
Just ordered one for my 16 Ray. Anxiously awaiting its arrival.
Range
YEA just plug and play. Had mine about 6 months, never take it out but I use tender all the time. U will like it.
Same here, installed it 6-8 months ago and been in ever since with no issues.
So people say it doesn't drain the battery. But they have the battery on a tender. Duh. I blamed mine for battery drain, removed and sold it. This is what "Range" has to say about battery drain.
Directly from the Range website (link at bottom): Testing has shown that the Range Device has a very small battery draw when the vehicle is off and in "sleep" mode. This is because it needs a monitor running to catch when the vehicle is started. This small draw is not enough to adversely affect battery life or drain the battery unless left in place for an extended period of time (i.e. more than a week or two). Our testing has shown that in the normal vehicle, it shouldn't affect vehicle starting for several weeks HOWEVER very cold or very hot weather can drastically reduce battery capacity, as well as any other accessories or modules in the vehicle that stay "awake" with the key off. Many security systems, aftermarket radios, plug in phone chargers and so on may also have a slight drain when not in use, so best practice is to unplug the MDS Manager when you know the vehicle is going to be sitting without starting or driving for several days. To add some more detail:
https://rangetechnology.zendesk.com/...5-Battery-Draw |
I've had mine for a long time. Always leave it plugged in. I don't drive my car a ton and it has sat for a month plugged in and I have not seen any battery drain issue (without the trickle charger). If you are not driving your car for more than a month you should have the charger plugged in anyway. So in my book totally a non-issue on the battery drain.
No battery drain with version 8.6.
Originally Posted by bbjohn
(Post 1598582279)
Originally Posted by Walt White Coupe
(Post 1598582394)
So you know more about the device than the manufacturer????
Range has changed this and the battery draw is much less than other factory equipment that constantly pings the cambus .... There are many of us who leave our cars unattended for long periods of time and do not have any issues. With all that said , Range Device or not if you leave your car for an extended period of time without a trickle charger you will return to a dead battery Dave |
If it starts throwing Check Engine lights. Remove while driving and pull the codes then contact Range.
By default Range clears all codes at restart. But if you get codes while driving, there might be a problem with your unit. How does he know this? :banghead: |
Just one more time, what I quoted from the Range Website is on the site right now. Apparently, they reduced the problem with their latest update but did not eliminate it, according to them.
Originally Posted by MikeERWNC
(Post 1598582470)
By default Range clears all codes at restart. But if you get codes while driving, there might be a problem with your unit. How does he know this? :banghead: Pic below is a pic of the box that the Range device came in. Note the bottom IMPORTANT warning. https://cimg2.ibsrv.net/gimg/www.cor...595b20981b.jpg |
I have been using my unit for at least six months, car battery is three years old, never on a charger and I have had no problems with the unit running the battery down even if the car sits for a week.
"So you know more about the device than the manufacturer???? "
I had a previous version that would drain the battery in a few days. Had it updated by Range (8.6) and now can leave the car for several weeks and it starts right up. And no, I don't know more about the device than the manufacturer. Since it probably uses some power I will change my statement to: No SIGNIFICANT battery drain with version 8.6. :cheers: |
Originally Posted by Spice red Ed
(Post 1598582553)
As far as the warnings on the box and the web site , I am sure they are leftover from the older versions and also a CYA There are thousands of the new devices out there as it works for every V8 GM that has AFM/DOD and with this many out there are am sure there would be some scathing reviews which there are not... just look at how many reported on here no problems with the latest release Dave |
I have a 2019 Grand Sport A8 with just over 1000 miles now. No shudder issues or RPM surges to date but I plan to purchase the Range device soon. Does anyone know if the Range device will positively impact the hard 1-2 shift on the first shift of the day?
Thanks Jim |
Originally Posted by javenius
(Post 1598582690)
Thanks Jim Dave |
(Post 1598582690)
Thanks Jim To avoid the first hard 1 to 2 shift, after you start the car with it still stationary paddle up to second and then back to first. This takes care of slow initial fill of the engaging clutch pack used for engaging second gear. Not sure why GM hasn't done this in software to do a partial pre-fill of this clutch pack at startup since the transmission is now in its fourth model year and showing the same issue now as it did in initial production. My 2001 GMC pickup with Allison transmission was the first clutch to clutch automatic I owned and it had an issue with slow fill of one of its much larger clutch pack actuators, Allison (which was still part of GM back then) quickly updated the software to cure the issue by doing a partial prefill after cold start. |
