C5 Forgestar Hub Fitment Issue
Any C5 Forgestar guys out there (any generation for that matter)...I have an issue with the fit of my new Forgestar F14s. The size/backspacing are fine, it's not an issue with the wheels, but rather seems to be an issue with the axle hub. I tried my best to get a decent picture of it. The large threaded rod shown below protrudes past the front edge of the wheel so I can't put on the center caps. This is only on the rear wheels. The fronts were fine. Anyone else run into this? I tried contacting Forgestar but haven't heard anything back.
https://cimg7.ibsrv.net/gimg/www.cor...0d85a04a8c.jpg |
There are cases of this occurring, you can do 2 things sir
1. you can get raised caps from Forgestar 2. You can shave the the axle bolt down ( some have done this) Paul A. |
Awesome. Thanks Paul. I'll try getting in touch with Forgestar again.
Anytime and Happy New Year !
What did you end up doing?
I'd personally just shave the axle a little and be done with it. |
