C2 on a Rotisserie ??
Can anyone tell me if it is possible to put a C2 body on a rotisserie? I don't think I have ever seen one on a rotisserie. It would make working on the bottom of my car a lot easier if possible. Would it need special bracing?
Thanks, Sam |
https://cimg1.ibsrv.net/gimg/www.cor...bc83d1deff.jpg
not hard at all if you have a frame style rotisserie . |
Thanks Porchdog. Is the body pictured just mounted at the body mount points?
yes. there is another brace i made for the front mount that is not in this picture..
Thanks, I may be buying a rotisserie when the time is right.
I have an Auto Twirler. They make a good corvette frame support setup. It has the mounts for the corvette body. |
Originally Posted by Bob K
(Post 1598661551)
I have an Auto Twirler. They make a good corvette frame support setup. It has the mounts for the corvette body. :thumbs: |
if you can weld the one i built cost very little. i used heavy wall because it is used in my blasting business.
Originally Posted by porchdog
(Post 1598676206)
https://cimg5.ibsrv.net/gimg/www.cor...15d075ca18.jpg
pretty simple . built to use under different bodies . |
