Thoughts on this Dexos 2 oil?
Mobil 1 0W-40 seems like unobtanium for a lot of people or is pricey, what are motor oil gurus' thoughts on this alternative:
https://www.amsoil.com/shop/by-produ...tic-motor-oil/ Amsoil has both a 5W-30 and 5W-40 that are dexos 2 approved. Amsoil tends to be pricier than most typically brands. But at the cost of Mobil 1 0W-40 dexos 2, it seems like a reasonable alternative that is easier to source. |
I decided to use the Dexos 1 option 5w-30 Mobil 1 (regular) in my 2019 GS. It is about $26 for 5 quarts. "For the LT1 and LT4 engines only, if 0W-40 dexos2 oil is not available, SAE 5W-30 dexos1 full synthetic engine oil may be used for street use."
Cheers, MrHix |
Originally Posted by MrHix
(Post 1598622686)
Cheers, MrHix |
I just love discussions about oil...............you don't see many of them these days!!! :lurk:
Anyway, b4 l unsubscribe, here is the info you need so you can now close the thread................. https://www.walmart.com/ip/Mobil-1-0...-5-qt/23636902 |
Originally Posted by PureJoy
(Post 1598622854)
Originally Posted by MMD
(Post 1598622797)
ESP Dexos2 will extend protection of your cats. Its' additives will hasten cold start wear on the engine. Mobil1 ESP 0W-40 Dexos2 is widely available now. If you can't find it you're not looking. If you think you saving $$$ buying 5W-30 think again. Not in the long run. |
(Post 1598622985)
not dexo2 -> no warranty for you. The warranty on my 20yr old C5 is now invalid??? :rofl: |
(Post 1598622985)
not dexo2 -> no warranty for you. https://cimg7.ibsrv.net/gimg/www.cor...c19d9cacb8.jpg Bill |
Scroll down when you get the link page & it seems Chevy dealers use Walmart Mobil 1.....
https://www.chevrolet.com/certified-...ge-life-system |
Originally Posted by iclick
(Post 1598623005)
Why would you want to "hasten cold start wear on the engine"? I assume you mean reduce it. In some climates the difference between a 5w and 0w would be insignificant, especially people like me who live in the Deep South and keep the car in a garage that rarely falls below 50°F in the winter. What's more, in the context of average ownership (time or miles) would the difference, if any, be quantifiable?. Another factor to consider is the viscosity range, which for the 5w30 is 25 vs. 40 for the 0w40. That traditionally means more additives to boost the viscosity, which means that under high-temperature conditions those additives will likely break down more quickly and reduce viscosity. I couldn't say how much any of this would relate to overall expense or engine durability in the real world, but I would bet it would be insignificant for most owners.
(Post 1598622797)
I have 900 miles on my 2019 Stingray so it's not ready for an oil change yet but when it is I'm going to use what the manufacture recommends.
Another thing people never consider is the OLM algorithm GM uses in the car is based on using oil properties of their recommended oil. If you are using an off brand oil then all bets are off. The OLM reading will be bogus for other oils. So then, how do you really know when to change the oil? What...every 3,000 miles?...but are you sure? The LT1/LT4/5 engines are high-performance engines that demand a lot from the oil. How do you know the oil you use is up to snuff? |
(Post 1598623486)
If it is a DEXOS oil it meets GM requirements for oil. MY 15 has 5-30 Mobil 1 oil in it and has for almost 67k miles thats what gm recommended. I refuse to go into walmart and have not seen the 0-40 oil in other stores around my home in VA Of course I dont go in everyday to look either the last time was 3 weeks ago :flag:
Amsoil is terrific oil, without question. As long as it's full synthetic, Dexos 2 you're good to go. Any number of other brands are available at far le$$, than Mobil 1.
That's the Euro 0-40 which is not Dexos.
So what? Mobil 1 ESP 0w-40 is not available locally around me. Why do you feel the need to jump all over people who decide to use a different path? Obviously I "am not looking" for the right oil and I must "think I saving $$$."
I thought this was supposed to be a good place to get information . . . . . MrHix
(Post 1598622797)
What Mobil 1 said !!!
