Let's guess how much power
My build is coming to an end .
Some things have changed . But I've tried to stay on track to stop this thing from turning into a flower pot. Details .. Ls2 block Callie's dragon Slayer 4" crank Callie's ultra h beams Wiseco pro series pistoms trick flow 245s with BTR extra work. Ysi on a&a updated bracket 2.7 pulley Iw 10% overdrive Btr equalizer intake... ( When it gets here) A&A secondary fuel system (still need to upgrade in tank stuff) Fuel injector clinic 1650s It has a vrx5 cam in it. That Illprobably swap out. Johnson short travel lifters link bar Kooks 2 inch Cartek flip drive Compression is 9.2:1 I'm getting excited. Was curious what everyone thinks it will make https://cimg2.ibsrv.net/gimg/www.cor...764ecb9475.jpg https://cimg6.ibsrv.net/gimg/www.cor...bc6c72dda1.jpg https://cimg3.ibsrv.net/gimg/www.cor...362e4e548f.jpg https://cimg5.ibsrv.net/gimg/www.cor...592c231ec7.jpg https://cimg7.ibsrv.net/gimg/www.cor...9510c986e0.jpg |
Hopeing to be around 24 psi on the 402 cubic inches
Originally Posted by zerotosixzero
(Post 1598626558)
Some things have changed . But I've tried to stay on track to stop this thing from turning into a flower pot. Details .. Ls2 block Callie's dragon Slayer 4" crank Callie's ultra h beams Wiseco pro series pistoms trick flow 245s with BTR extra work. Ysi on a&a updated bracket 2.7 pulley Iw 10% overdrive Btr equalizer intake... ( When it gets here) A&A secondary fuel system (still need to upgrade in tank stuff) Fuel injector clinic 1650s It has a vrx5 cam in it. That Illprobably swap out. Johnson short travel lifters link bar Kooks 2 inch Cartek flip drive Compression is 9.2:1 I'm getting excited. Was curious what everyone thinks it will make https://cimg6.ibsrv.net/gimg/www.cor...bc6c72dda1.jpg I'll guess somewhere north of 800rwhp |
24 psi? Over 1000rwhp
(Post 1598626678)
I previously made 1025rwhp at 18lbs with small t3 6265 twins on a 427. You've got the extra drag, a few less cubes but you'll be close or over depending on psi
Best of luck! |
1053
well, i reckon 'why?' becomes an irrelevant question at this level of insanity :lol:
i'll guess 1069hp |
my guess, more than 699:woohoo:
1000++ |
1150 |
I would say 800+ but if you still have that plastic power steering pulley on it(looks like it) I would swap it out with a C6 aluminum one at the very least.....
1050-1100. Those pullies will spin the f**k out of that ysi. |
