Adding Tweeters to C4
The car is a 1989 with original Bose system and rebuilt amps from Dr. Don and appears to operate normally. The speakers are original and might be tired, but they look healthy. The system suffers from that typical "fried egg" sound on the highs and grows tiresome after awhile.
I am considering adding good quality stand alone tweeters to the front with built in crossovers. I need advice on what to put inline to filter out the highs on the stock Bose 4 inchers so all they have to produce are mids and whatever lows they can. Can anyone point me to something? Are there passive filters that will do this? For improved bass, I am adding a powered enclosed sub-woofer in the hatch area. |
You can design a simple 12db/octave passive filter to low pass the stock speakers and high pass your tweeters. You need to look at the specs for your new tweeters and the bose midranges to decide the right frequency to crossover at. Here's a good starting point, but there are lots of crossover calculators available online. See below:
https://www.google.com/url?sa=t&rct=...5EYEqW_s6qtEGU http://www.erseaudio.com/Second-Order-2-Way |
Originally Posted by daverulz
(Post 1598645777)
https://www.google.com/url?sa=t&rct=...5EYEqW_s6qtEGU http://www.erseaudio.com/Second-Order-2-Way I found some nice Focal 1.5 inch tweeters with flexible mounting that have a frequency response range from 4,000-21,000 Hz. Built in crossovers. I'm going to get someone smarter than me at Parts Express on the phone and see what they say. |
cool, what Focals are you looking at?
Focal TWU 1.5 inch. The specs look good and they have flexible mounts.
Nice, I'm sure you'll see an improvement. Do those tweets come with a crossover? What are you going to run them off of? the bose amp?
Yes, they come with built-in crossovers. They are 4 ohms, however, so I am curious how they will behave wired in parallel with the Bose amp, which is also driving the 1 ohm Bose speakers. I found an online tool that calculates 0.80 total ohms across them both. We shall listen. Parts Express has recommended an appropriate air core inductor to filter 4000hz and above on the originals and turn them into mids. I don't think they produce much bass in the first place. I'll report back when I get them installed.
I'll just say this...you're on a slippery slope. Before you know it you're going to be looking to pull the bose stuff and for places to stash amps. Just sayin' - this is how it starts.
Ha! You are probably right but if this can just get rid of that fried egg sound, I think I will be happy. I don't play the music much with the top off anyway. The exhaust is enough.
So, 3.5 months later and I can now report my results. Other projects got in the way.
My goals were to keep the stock system, improve sound quality, staging, get rid of that Bose "fried egg" sound at the high end, and add some real bass. Hope someone finds this useful/interesting. Here is the work I have done on my original 89 Delco Bose system:
Original Bose 4.5 inchers from the 901 are reported to be used in this DelcoBose application. Their range is reported to be 83 - 15,000Hz using the Bose equalizer. New ranges: Kenwood Sub = 35 - 125Hz. I have the crossover set at 125. Bose Mids = 83 - 4000Hz JL Tweets = 3.6 - 22,000Hz I'm calling this a success from my perspective. I'd enjoy hearing any comments/suggestions. Now, let's see if the system holds up! |
