Does anyone have any ECM pins w/ a bit of wire on them?
I need to redo a few of mine and I'd rather not but just the micro-pack 100W terminals and trust my crimp if I don't need to. I suppose worst case I find a junk yard to go to town but it's very cold here in Illinois right now.
Thanks much Dave |
TTT, hoping to avoid having to get to a junkyard still.
Dave |
How long of a lead do you need on them? |
2-3' would be sufficient. Funny story, I have my wideband right above my ECU but have the drivetrain separated from the body. Had the wiring hanging and my robot vacuum sucked up the wires while cleaning the floor the other day. Ripped off the end but I'd rather redo it properly and I'll just crimp some molex pins (the pins the wideband uses) and just wire directly from the ECM to the wideband w/o having a soldered connecting between the two.
Dave |
ECM pins
I might have what you need, what color wires, and how many?
Color isn't a huge deal. Red / black or a dark/light are fine. Just need to signify power and ground. I'd like maybe 5 or 6 if you have them just to have a few to do some testing with as well.
Dave |
ECM pins
I will look in the morning.
Thank you
Dave |
I ended up only having the terminals themselves, sorry about that! |
Np thanks for the update. Still looking guys.
Dave |
I got a bunch of them. pullouts from when I converted my 2006 motor to stand alone for an ls conversion.
Send address and I'll send half dozen your way. |
PM Sent, thank you sir!
Dave |
