Adam's NEW Ceramic Spray Coating! Plus 15% Off Storewide!
Introducing Adam's NEW Ceramic Spray Coating!
Adam's Ceramic Spray Coating combines the enriched gloss, extreme hydrophobic properties, and effects of a ceramic coating with the application of a spray. This 9H ceramic coating has been reengineered to be sprayed out of the bottle and wiped onto the service, making application easier than ever before. https://adamspolishes.com/shop/speci...ategory-1.html |
Do the same rules apply as the previous coating? Clean residue off from paint correction, dispose of microfiber towels after application, wipe on in 2 directions like previous coating... ??
has anyone tried / used this - I currently use Kamikaze and want to know if this compares? how does it last? how does it look?
any comments - I like it but before I pay that much I want to make sure it works - I need to purchase something it is time to redo my vehicles (been 3 years since last treatment) |
The Adan's forum says it hasn't started shipping yet. Hoping it's a good product since I haven't tried any ceramic yet. I'm always so burnt out after paint correction that I just haven't had the enthusiasm to try ceramic yet since it's somewhat time consuming to apply/remove. I thought I read that it only lasts 6-8 months,it would be much easier to use vs. the traditional method which I personally wouldn't have the patience for.
This looks very promising. Looks like a very user friendly ceramic. Anxious to see reviews on this product.
Originally Posted by charley95
(Post 1598656301)
Why can’t it be smelled? Drying the product or is it toxic? |
another question - if I have been using a detail spray on my car - I need to remove all that to use the Adams Ceramic Spay Coating? after I use this do I then use detail spray to help keep the coating? I wash my car every week and then apply detail spray - how do I manage with this?
my car was last Ceramic Coated 3 years ago with Kamikaze - had great success - but I keep reading about Adams - and before I repurchase Kamikaze I am looking to see if the Adams Ceramic Coating is as good and also if the Ceramic Spray Coating is good to use. |
Originally Posted by walker3
(Post 1598784273)
my car was last Ceramic Coated 3 years ago with Kamikaze - had great success - but I keep reading about Adams - and before I repurchase Kamikaze I am looking to see if the Adams Ceramic Coating is as good and also if the Ceramic Spray Coating is good to use. https://adamspolishes.com/shop/exter...prep-16oz.html |
Originally Posted by Adam's Polish
(Post 1598788911)
You would Clay, Polish (if needed) then you would use our Coating Prep to remove any oils or polishes before coating.
Originally Posted by tabbruzz
(Post 1598860561)
So I have a question too.....After the ceramic is applied and such what would I use in the way of a detailing spray. I had my car a long time and only use detailing spray to keep it cleaned. Believe it or not the car was only washed with actual soap and water once and this was after driving through a swarm of some kind on insect at 110mph..It was at the end of a drag strip...The paint is in outstanding shape, but if ceramic is the best to keep it this way I would like to give it a shot..
You can still do light dusting with Detail Spray and every so often you could use our Ceramic Boost to help you maintain your coating. Thanks! https://adamspolishes.com/shop/exter...-16oz-kit.html |
(Post 1598867529)
Can't go wrong with CB, it's an awesome product.
(Post 1598867529)
(Post 1598877652)
If I use zaino z6 detail spray often when should CB be used? Should it be a once a year thing or is there no issue using it often?
(Post 1598998894)
DS is for removing light dust, our Ceramic Boost is for protection. So you could Boost every 3 to 6 months, depending on how much your car is exposed to the elements.
https://youtu.be/5KL_77SLeM8 |
Would you recommend this or the window sealant for a windshield?
Can I use the Waterless Wash with the Ceramic Spray?
Getting my bottle today and will give opinion when I try it. I'd prefer that Adam's would offer it in a clear bottle so I can see how much is left. It's no longer offered in the clear bottle like in the video.
