intake And tune
Hey guys. i drive a c6 ls2 and im looking for a cold air intake to install. However, i live dubai. It can get really hot and sandy at some times. im also looking for a hand tuner. Some friends recommended hp tuner and some sct. what do you guys reccomned. ps im a new member, im sure some will say that this has been discussed before but i couldnt find them ! Sorry |
Moved over to C6 General |
Originally Posted by Youssefc6
(Post 1598666673)
Hey guys. i drive a c6 ls2 and im looking for a cold air intake to install. However, i live dubai. It can get really hot and sandy at some times. im also looking for a hand tuner. Some friends recommended hp tuner and some sct. what do you guys reccomned. ps im a new member, im sure some will say that this has been discussed before but i couldnt find them ! Sorry HPT is my choice and recommendation. I cannot recommend a cold air intake. Being in Dubai, regardless of the intake you use (unless it is refrigerated), you cannot overcome ambient air temperature once over 32*C. Then, timing will be reduced regardless of the intake, or no intake at all....just physics. On an LS2, you can improve breathing somewhat with a cold air intake, but only when ambient air temps fall below 30*C. |
keep it stock.
To be safe from ingesting dust, I'd recommend a Z06 or LS3 intake with the stock filter. Nothing else filters better. If you want cooler than underhood air, then prop the shroud open (search $2 propped shroud) and use a Halltech beehive or fabricate something similar to keep the engine compartment clean.
LS3 Air intake with reusable filter and Diablo tuner!!! BIG improvement.
