Remove Top Cap on M6 Shifter
Can you remove the top cap on the corvette c6 manual shifter. I know you can remove from an automatic but does the manual one come off. |
If you are talking about The shifter knob one screw and it removes |
Knob
Not the entire knob. That is easily removed. Talking about the top cap with the shift pattern. Would like to replace it. |
Yes it just pops off. I wrapped mine with black vinyl because I removed all silver from the interior. |
Knob
Thanks. Going to do something similar andcarap in carbon. |
Originally Posted by jeffwest5599
(Post 1598669391)
Yes it comes off.
Top
i put a heat gun to it and it popped right off. Thanks. |
(Post 1598672430)
I took mine off so I could spray the handle to match my interior. Mine just presses on and was able to remove it by slowly prying it off with a flat-head screwdriver from both sides, rocking it back-and-forth till it popped off. https://cimg6.ibsrv.net/gimg/www.cor...496a58f45f.jpg https://cimg6.ibsrv.net/gimg/www.cor...a344264401.jpg |
