For those with a custom exhaust: catback or axle back?
Which do you have, and why did you choose it?
I chose the Billy Boat Fusion 3 system for NPP-equipped cars. It's not really an axle back, but neither is it a cat back. The factory mufflers were replaced, and it came with over-the axle pipes with the AFM valve connections. I chose this set up because I could get a good muscle car sound without having to change the X-pipe and exhaust manifolds, and I could retain the NPP functionality. I'm very satisfied with it, and it has NO drone.
Corsa Xtreme and Double Helixx X-Pipe
Cause it is SICK sounding :yesnod: Regards Chip |
I bought my system from this guy above. :thumbs:
Bought my Borla Atak with black intercooled tips from Chip as well! Also have the Borla X-pipe.
Exhaust sounds great (though not nearly as low and aggressive as the Magnaflow I had before) but it's definitely louder than stock and it's actually quiet when cruising. Something the MF was not. |
I have the Corsa set-up (X-pipe and Xtremes). Deep throaty tone without the drone. Quality product, nice welds, and the tips look great. |
Originally Posted by Slick6
(Post 1598670979)
Originally Posted by Sconn
(Post 1598671338)
Exhaust sounds great (though not nearly as low and aggressive as the Magnaflow I had before) but it's definitely louder than stock and it's actually quiet when cruising. Something the MF was not. :thumbs::thumbs: :seeya Tks Guys Chip |
(Post 1598670952)
If you're going to do exhaust, do yourself a favor and get the whole system from the factory cats back. I did the Bolra catless Xpipe + Borla S type NPP/AFM rear and it sounded great. Then I added ARH midlength headers and it sounded even better but it is very loud at full throttle.
Originally Posted by TriPinTaZ
(Post 1598672830)
Originally Posted by jtranger
(Post 1598672068)
Does the car quite down significantly with the valves closed? How difficult is the install?
Originally Posted by Custom Corvette Accessories
(Post 1598670966)
ttt
X pipe and cat back with the NPP put the AKRAPOVIC onto the car.. Love the sound and for sue=re very lite system. Robert
(Post 1598687071)
Chip, Can you give installation instructions on the Fusion axle backs? Do you have to remove the rear valance or any other major parts or is it a simple r&r? Thanks
however You do need to remove the rear valance - the rest is pretty straight forward Regards Chip |
