Help with a LS7 N/A setup. please step in if you have one
https://www.yellowbullet.com/forum/i...cons/icon1.gif LS7 heads who is the best for a N/A setup?I have a LS7, in my 32 ford truck, with a turbo 400. Right now it has a BTR stage III cam, headers, and a tune. The heads were fixed by WCCH. And the spring, and retainers, installed for the cam. Other than that the motor is stock.
I am would like to keep it N/A and 93 pump gas. That is how it is now. I have been reading and doing research, until my head & eyes hurt. I thought a aftermarket head, intake and throttle body change. Might pick it up, et wise at the track. But of course everyone says their heads are the best, some say fast, some same MSD for the intakes. I was hoping for some HELP from someone on the site.THAT COULD STEER ME IN THE RIGHT DIRECTION Who have real world N/A setups. . Before I waste good money, with the wrong combo. |
On intake nanifold, what will fit under a C6 hood, will air starve the hell out of the motor past 6K isntead.
So if you want to spin the motor to 7K, need to get it to breath correctly to 7K with a intake manifold that will do that. |
Headers? (need them) then get MSD intake with 102 throttle body and CAI and your good to go! :thumbs:
Originally Posted by Todds427
(Post 1598676163)
https://cimg9.ibsrv.net/gimg/www.cor...3b6a469040.jpg |
That must be a riot, lets see the rest of the car! Air intake setup is interesting.
You're at the point where is little more powa is going to cost a lot more coin.....unless you add a blower. Then, it's still going to cost big time. Enjoy that bad girl in her current iteration!
https://cimg9.ibsrv.net/gimg/www.cor...0a391033fc.png
Here you go guys. |
Daaaayum. If I could tow my boat with that, I wouldn't even need to catch any fish!!!!
Originally Posted by old motorhead
(Post 1598678242)
It's blower time if you want to add significant power. It's visually spectacular as it sits. Add a top mount blower if you want to take it to the next level. My wife would leave me for your truck!
Edit: I think my dog would leave me too!!!! |
(Post 1598678771)
Edit: I think my dog would leave me too!!!! Thanks But blowers and LS7 blocks don't play well together. If they did it would already have one. |
Originally Posted by bada
(Post 1598679240)
Thanks
But blowers and LS7 blocks don't play well together. If they did it would already have one. As for blowers on the LS7, not used in a way you are thinking with major boost levels, but lower boost levels to get the motor to breath all the way up to 7K in the limited engine bay space under the hood instead. So stock dyno for a LS7, and does not matter what you are playing with, it still go winded at 5.6K rpms due to the restriction of the intake manifold. https://cimg3.ibsrv.net/gimg/www.cor...a0b9144041.jpg So simply put, the motor wants to rev to 7K, and just a mater so is can breath correctly to 7k rpms so the power band does not go flat at the 5.6k point isntead. Hence stock LS7 with OEM exhaust manifold, standard TVS-2300 will get you to over 650HP without breaking a sweat. The reason, the S/C will push enough air into the motor to get to pull hard all the way up to the 7K point. Better yet, since the Torque goes linear off idle with a S/C, your pulling dam near 600lbs of torque before even getting to 2K rpms. Hence S/C on a stock LS7 ends up with the power and torque looking like this isntead. https://cimg4.ibsrv.net/gimg/www.cor...56759b3915.jpg So bang for buck, S/C will get you there the quickest way, often the least expensive way, and on a stock motor to boot. |
Originally Posted by Dano523
(Post 1598679366)
As stated, you have the room for a better intake manifold to promote better air flow in the higher RPM's, so use it to your advantage.
A TVS will add about 20hp per pound of boost. The way you're set up now, you should be over 550. So, 5ish psi should put you over 650 at the wheels. An LS7 will get along just fine with even more boost than that. Pulley the blower for 7 or 8psi and you'll have a real beast on your hands.
No need for aftermarket heads on this car...stock castings with a good CNC program flow exceptionally well. Having said that, ported heads don't really shine without adding an aftermarket cam. Can you CNC them? Sure...but the time and money involved to R&R the heads for CNC on a stock cam LS7 will not net that much of a HP gain. "Worth it" will be entirely up to you though...
As for intake manifolds...a ported MSD will always post up more gains that a ported FAST. Either will make decent gains...but MSD > FAST. TB change? Nah..not worth the money for your build. A NW 102 TB is worth about 6 hp on a max effort NA LS7 build (meaning 600+ rwhp). You're better off sending your OE TB out to be ported along with whatever intake you choose. The ported OE TB isn't for HP though..strictly throttle response. As for an air intake...you'd have to go custom fab. Not sure what filter you run, but the "attack blue" is about the only drop in filter that has shown proven gains on the ZR1, and it also fits the OE LS7 air intake. My recommendation...start with a ported MSD/ported OE TB, and a drop in "attack blue" filter. Those are all pretty easy add-ons, and you can go from there if you're still wanting more. If so...you can always send your heads back to WCCH for their CNC program, but I would recommend looking into at least a mild cam. If its me, I'd go custom mild cam from Cam motion. Something that doesn't put too much stress on the valvetrain. |
Originally Posted by MTPZ06
(Post 1598684473)
Originally Posted by RogerRamjet21
(Post 1598684662)
Did you read his post at all? He already has headers and cam... "I have a LS7, in my 32 ford truck, with a turbo 400. Right now it has a BTR stage III cam, headers, and a tune."
In that case...ported MSD & NW102 is next step...but you'll need to modify your air intake to fit the 102 TB. I imagine your WCCH heads are already CNC'd then OP? |
(Post 1598672877)
I am would like to keep it N/A and 93 pump gas. That is how it is now. I have been reading and doing research, until my head & eyes hurt. I thought a aftermarket head, intake and throttle body change. Might pick it up, et wise at the track. But of course everyone says their heads are the best, some say fast, some same MSD for the intakes. I was hoping for some HELP from someone on the site.THAT COULD STEER ME IN THE RIGHT DIRECTION Who have real world N/A setups. . Before I waste good money, with the wrong combo. My best ET was last February when I ran 9.933@136.70 with the car, which is an N/A LS7 and 6L80E transmission as well as several other mods. Aftermarket heads in my opinion are not needed as I'm running stock heads that had the valve guides replaced, were milled .030 and ported by a local shop meaning that I didn't spend a ton of money on them. I'm running a stock, unported throttle body that was originally on my LS2. I had a ported throttle body on the car in an earlier build but didn't notice any increased horsepower or throttle response. I'm running a ported stock LS7 intake manifold as I tried both an unported MSD and a ported FAST 102 and in both cases I may have seen marginal (at best) ET improvements but definitely not worth the cost. I also tried a Vararam intake in an earlier build as well as a couple of others and again, didn't see enough of an improvements to justify the cost. I'm currently running a stock intake with an Attack Blue filter which is worth the money, as I picked up a full tenth after installing it. The other list of stock parts includes spark plugs, coils and wires. |
Originally Posted by subfloor@centurytrans
(Post 1598684827)
I'm guessing I might catch flack for some of my opinions, but all I can do is share what works REALLY well for my setup. I'm strongly of the opinion that GM did a lot of things properly with the LS7 so why try to improve on what already works.
My best ET was last February when I ran 9.933@136.70 with the car, which is an N/A LS7 and 6L80E transmission as well as several other mods. Aftermarket heads in my opinion are not needed as I'm running stock heads that had the valve guides replaced, were milled .030 and ported by a local shop meaning that I didn't spend a ton of money on them. I'm running a stock, unported throttle body that was originally on my LS2. I had a ported throttle body on the car in an earlier build but didn't notice any increased horsepower or throttle response. I'm running a ported stock LS7 intake manifold as I tried both an unported MSD and a ported FAST 102 and in both cases I may have seen marginal (at best) ET improvements but definitely not worth the cost. I also tried a Vararam intake in an earlier build as well as a couple of others and again, didn't see enough of an improvements to justify the cost. I'm currently running a stock intake with an Attack Blue filter which is worth the money, as I picked up a full tenth after installing it. The other list of stock parts includes spark plugs, coils and wires. No flame thrower from me...along my line of thinking as well. I am surprised you didn't see much merit in the MSD & FAST intakes. I don't know how much port work your castings had in them though. If the OP's heads are CNC'd not just "fixed" as he stated...he has an excellent port job then. I'd be shocked if he didn't see at least 30 rwhp with a ported MSD & NW 102 TB. Heck...the MSD should produce that on its own (without the 102 TB). "In theory", that should be worth 2-3 tenths in the quarter...but time slips matter more than theory. |
(Post 1598685081)
