DCT Power-Brake Question
For those familiar with the DCT:
Can you "power brake" a DCT? I recognize that the DCT does not have a torque converter that you could power brake for a launch. So...how would a DCT perform the same power brake? Standing still, with the DCT in "D" or "1" the clutch is disengaged. If you have foot on brake and gas, what will happen as opposed if same is done with A8? |
Sort of..... depending on the brand, you can place your left foot on the brake, then floor the accelerator with your right foot. Then wait for the RPM to stabilize at 4,000 RPM. Remove your left foot off the brake pedal and off you go.
When you are holding the brake pedal with your left foot and the engine RPM's are at 4,000 RPM's, it takes no more force to hold the brakes then if you were holding the brakes with a manual transmission while holding the RPM at 4,000. RPM. No power braking required, as the clutch is not transferring any power to the transmission until you actually release the brake and then the car's computer engages the clutch, automatically. The car's computer modulates the DCT's 1st gear clutch for beat acceleration. |
You can, but you shouldn't need to. I have power breaked my Macan just to see. In compression to the launch control, it is not worth it. Launch control revs to 4-5k rpms and dumps it.
+1 Launch Control (electronic). This how my GR6 works.
Hold brake all the way down. While holding brake, hammer gas pedal to 100%. Here is where the ECU will recognize you're attempting a launch, and will slip the clutches, while building to preset RPM. Next, dump the brake pedal. Profit. |
On my Boxster, I place the system in Sport+ mode, hold the brake and floor the go pedal. The computer notes that a "launch control" is wanted. Revs go to the Rev limiter and when the brake is released, the computer controls wheel spin, revs etc to effect a launch with the least wheel spin with max power/acceleration. Road and Track did a "torture test" on a PDK equipped 911, 50 back to back runs with no cooldown in an attempt to "break" the system. They gave up after 61 back to back runs. Here is the video. https://www.youtube.com/watch?v=A5DR...ature=youtu.be
So based on the above comments, it looks like there is no way to do a smoking burnout.
The ecu will control wheel spin? |
On my M3 you can hold the brake, floor it, and it does a quasi launch control where it will rev to 4000ish.... if you go through a stupidly complex series of steps you can put it in actual launch control. In real mode once it is engaged you end up flooring it with the paddle pulled and foot off the brake. It revs to 5500 or so, let go of the paddle and it goes and does everything else for you shifting included.
Originally Posted by Perf n Restore
(Post 1598695479)
The ecu will control wheel spin? Keep in mind this is Porsche's programming and really can't be compared to anybody elses DCT control. |
Assuming RWD only and no line lock, it would kind of be the opposite sequence if you wanted a burnout.
Traction control OFF Hammer the gas pedal. Immediately stomp the brake. No launch proceeds to burnout. M3 and 911 guys can confirm? The GTRs buy AWD electronic controllers, to tell the trans and ETS where to send power, and disable launch control. This is how you see GTRs do burnouts at the strip. |
Originally Posted by TheSenator
(Post 1598695677)
(Post 1598694689)
Can you "power brake" a DCT? I recognize that the DCT does not have a torque converter that you could power brake for a launch. So...how would a DCT perform the same power brake? Standing still, with the DCT in "D" or "1" the clutch is disengaged. If you have foot on brake and gas, what will happen as opposed if same is done with A8? When you hold your foot on the brake and add gas, the ECM detects no forward speed and won't allow clutch to engage. Launch control raises the RPM to what the manufacturer determines and engages the clutch when the brake is released. Only Porsche PDKs can handle continuous abuse. Some of the things the ECM has difficulty with is upshifting when slowing down or downshifting when accelerating. Short shifting is great with a stick shift to control torque in a turn exit. I changed my cam in my roadster, not for more power, but lower torque at low rpms. Now everything is done with a computer but you must assist it with knowledge. For instance, if you are on an incline at a stop, keep your foot on the brake to keep the clutch dis engaged. creeping in traffic especially on a hot day, keep pulling both shifts to let the car roll in neutral on early cars. Watch for high clutch temps. I don't know what car you have, but hold the brake and add gas. Watch RPM. It might rise and fall while the ECM figures out what you are doing. Try it in LC and D. Ask the question on your cars's forum. |
Power Braking on any DCT is shaving life those clutches in good amounts, Brake Boosting is another way to kill a DCT.
Use launch control. Problem solved.
Lots of performance cars these days offer line lock if you really want to do burnouts: https://jalopnik.com/all-ford-mustan...car-1796526813 |
Originally Posted by jefnvk
(Post 1598704103)
Lots of performance cars these days offer line lock if you really want to do burnouts: https://jalopnik.com/all-ford-mustan...car-1796526813 Every time you switch on TC or switch off VDC, they are watching you. The GPS tells which track or drag strip you're at. The C8 will have similar algorithms. The GTR will go .2 of a second slower if you just stomp on the gas. The Nissan police will let you go free, IE: if you don't have a clutch job before 200 miles is up, |
Originally Posted by Shaka
(Post 1598704266)
Each manufacturer has an abuse clause in the small. print. Abuse can be verified easily because it is retained in the car's computer. The cars brains can find you guilty and sentence you by not honoring the warranty. No shit.
Some manufactures void the trans warrantee for launch control usage or limit the number of times it can be used. |
Originally Posted by NY09C6
(Post 1598705382)
Originally Posted by ByByBMW
(Post 1598709390)
Do you have some links or other info as to which manufacturers void those warranties?
(Post 1598711277)
Nissan with the GTR is the one that comes to mind. BMW has warnings to limit its use due to excessive wear and tear. |
