To supercharge or not
Rather than taking a bath trading a 2019 grand sport for a 19 z06 would like opinions on adding a supercharger from those that have done so. Any reliability issues or overheating problems ? I assume you would lose your factory warranty. Also effect on fuel economy, and no I didn’t buy it for that reason but it’s kind of nice to get 30 mpg when just cruising. Also wonder what it would do to trade in value? Thx |
IMHO.. 1. The more power you make,the more fuel you'll burn.
2. You will lose the factory power-train warranty. 3. You will not recover any money invested in mods. |
Originally Posted by John Micheal Henry
(Post 1598708675)
I think you’ll take a bath either way. Except with the z06 it’ll be easier to sell and get more of your money back. That’s what I’ve seen here over the years in the for sale ads. Also since the super charger doesn’t kick in until a certain rpm your fuel economy should still be good. Not sure what you lose just spinning the supercharger while cruising down the highway. Probably not going to get 30mpg like the LT1 but close. |
(Post 1598708675)
Your fuel economy won't suffer much until you engage in some spirited driving. You won't get much money back when you sell after doing the supercharger & yes, you will lose that warranty
Are you thinking roots type or a centrifugal blower? I put a Paxton centrifugal on my 2008 Mustang along with several other mods, and the fuel mileage didn't take a drastic hit. The centrifugal route is better if you don't want to be under boost all of the time.
I ran an A&A Vortex centri supercharger on my C5 Vette for several years. It produced 502 hp at the wheels at 10 lbs of boost. Not bad for an otherwise bone stock LS1. As long as I kept my foot out of it, the gas mileage was about the same as without the supercharger. Unlike the rootes type unit that the factory uses, my centri did not provide any significant boost until about 2500 rpm. You can probably have a centri installed for $7000 to $8000 dollars along with a tune. Less if you do the work. I never had any overheating issues with it, but it was a C5 not a C7. As far as trade in value, it will probably lower it, but you can always remove the centri, put the car back to stock, and sell the supercharger separately. I sold my C5 with the centri on it for a premium, but found a buyer who was looking for a supercharged car. Not sure where you are located, but smog might be an issue. A&A has a 50 state legal setup for the C7. Not sure about the other supercharger manufacturers.
Here is a link: https://www.aacorvette.com/ Phil |
It'll sure change the maintenance tail unlike the Z that already has a good warranty for being supercharged. Plus, it will be harder to sell or trade when the time comes, or at least in my experience did. I guess it depends on if you are planning on keeping her and don't mind a tweak or two every once in a while, imho.
(Post 1598708675)
2. You will lose the factory power-train warranty. 3. You will not recover any money invested in mods. OP unless you're tracking extensively you will not overheat. And centrifugal kits run cooler than z06s so if you have all the cooling already your car would be better suited Problems? Change plugs every 2 years, change supercharger oil every oil change if centrifugal and you're set. I've put almost 30k miles on mine and some 30 track days and some 30 1/2 mile runs. If you don't plan on going past stock Z06 power this is the way to go. If you plan on going over, then the forged pistons on the Z06 (only major difference really) would allow that. Cruising I lost like 1-2 mpg. Putting Z06 stage 3 front and 2 rear aero on my z51 made a larger mpg difference. |
Originally Posted by ImpliedConsent
(Post 1598709230)
Sounds like I just need to keep it stock |
I have an Edelbrock E-Force on my 15 Stingray. The gas mileage is unaffected. I get the same now in normal driving as before. I have had no overheating or other problems since installation.
Get a Z06 and call it a day. |
Originally Posted by Corvette farmer
(Post 1598711542)
Trade up to the Z06 and all the reasons for not adding a supercharger to your GS go away.
I've spent decades with supercharged and turboed cars, aftermarket and factory. Know full well there are good reasons GM, Chrysler, and others all make serious internal modifications to "blown" engines. I would never simply add a supercharger to a factory normally aspirated engine without prepping it properly. Even then, there are no certainties unless you do all your own work, or know really well those who do.
I know this is not the after-market's line on their products. But, unless you wish to drive like a ninny (then why do any power-adder, anyway) you will be at risk, imho. Obviously, a lot of people buy and install such on otherwise stock engines... not my choice, thank you... since you asked... :yesnod: |
Originally Posted by Avanti
(Post 1598712238)
Trade it in on the Z. It will be cheaper in the long run.
Originally Posted by BrunoTheMellow
(Post 1598712453)
My 30k miles , 30+ track days, 30+ half mile runs procharged only z51 and many others say you're fine.
I was thinking of a centri style SC and Alky/meth injection. Not looking for crazy boost, so maybe Alky/Meth isn't needed? 600 - 650 at the crank is safe on stock internals? Thanks. |
