Corvette Camaro Tuner in Tampa E85
Check out my website -->>>> www.TampaTuning.com
Check out my YouTube channel https://www.youtube.com/user/tampatuning/videos I calibrate the most LS series cars in the Tampa area with Corvettes and Camaros being my highest volume cars to tune . Tampa Tuning is the home for street performance tuning starting at $380.00 Corvettes and Camaros at the stock to bolt ons level. My street tuning process takes several hours to complete. Its the best way to collect scanner data for low end drivability, cruising, and WOT under actual load and airflow of the vehicle. My HP Tuners interface has unlimited credits for LS1, LS2, LS3, LS6, LS7, LSA, LS9, L99 engines :thumbs: C7, Gen6 Camaros, and trucks are $100 more. Great modification for the buck! Corvette Camaro Tuner in Tampa Instagram : TampaTuning OUR TOTAL STREET PERFORMANCE TUNING PACKAGE FOR GM LS1-7 VEHICLES IS $380.00 WITH TRANSMISSION PACKAGE INCLUDES: www.TampaTuning.com Read and reprogram your PCMs settings and perform real time scanning diagnostics for the best results Increase power enrichment rate mode Examine and change timing tables for additional horsepower & torque gain Optimize your vehicles Air and Fuel Ratio monitored by the NGK/ AFX wideband unit Reduction of intake air temperature table (heat soak) Desired rev limiter adjustments Park, neutral, and in- gear idle adjustments with and without A/C active Adjust power enrichment delay to immediate Engine torque management system reduced Transmission torque management system reduced Transmission shift points enhanced Transmission shift times reduced Transmission shift pressure firmness enhanced if needed Skip shift deleted (CAGs 1st to 4th ) Fuel injector rescaling for aftermarket injectors if needed Cooling fan activation temperature and percentage of cooling recalculated Perform speedometer re-calibration for rear gear ratio and tire size change www.TampaTuning.com Email Click here : Tuning@TampaTuning.com Phil |
Corvette Camaro tuner in Tampa E85
Read some comments about Tampa Tuning : https://shop.tampatuning.com/testimonials.html
Read about what I change : www.TampaTuning.com I calibrate the most vehicles in the Tampa area and for the best price ! Check me out on Facebook : Tampa Tuning Instagram: TampaTuning. Want to go faster? Email me : Tuning@TampaTuning.com Corvette Camaro GTO Cadillac CTSv Challenger Charger Truck Silverado Sierra Yukon The BEST Tuner in Tampa Phil www.TampaTuning.com Email Click here : Tuning@TampaTuning.com Phil[/QUOTE] |
Read about what I change : www.TampaTuning.com I calibrate the most vehicles in the Tampa area for the best price ! Check me out on Facebook : https://www.facebook.com/tampa.tuning Instagram: TampaTuning. Want to go faster? Email me : Tuning@TampaTuning.com Corvette Camaro Cadillac CTSv Challenger Charger Tuner in Tampa Email Click here : Tuning@TampaTuning.com Phil
Originally Posted by Tampa Tuning
(Post 1598755126)
Read about what I change : www.TampaTuning.com I calibrate the most vehicles in the Tampa area and for the best price ! Check me out on Facebook : Tampa Tuning Instagram: TampaTuning. Want to go faster? Email me : Tuning@TampaTuning.com Corvette Camaro GTO Cadillac CTSv Challenger Charger Truck Silverado Sierra Yukon The BEST Tuner in Tampa Phil |
Corvette Camaro tuner in Tampa E85 cammed headers
Tuner in Tampa
Bump TTT I still calibrate the F body line
Camaro Corvette tuner in Tampa |
