Looking for a zf lt5 input shaft
Does anyone have an lt5/zr1 zf input shaft for a blue tag trans? The newer the better
Thanks |
Originally Posted by wfot
(Post 1598744074)
Thanks 2 input shafts L98/LT1 & LT4 then LT5 |
I would suggest checking with ZF Doc
LOL,
thanks, already on it. he does know his stuff and is a wealth of knowledge. John |
If you can locate the transmission slip yoke needed, I believe about any driveline shop could build you a shaft of the proper length you need. That's where I would be looking too. They might even be able to supply the slip yoke as well(?).
Justa thought! . |
