Brake caliper piston tool
Can I use the usual parts house disc brake caliper compressor tool on my C-6 Z-51?
just use a small c-clamp...
Had the rears apart on mine yesterday,small vise grip c clamp worked well
C-Clamp with old pads. Turn the pads around so the pad material is against the piston(s) and use the C-Clamp to push them back (make sure your brake reservoir cap is off and you remove a bit of fluid from it or it may overflow. Use a C-Clamp like in the photo I've attached (I probably bought it at Home Depot).
https://cimg7.ibsrv.net/gimg/www.cor...32871c1f77.jpg |
Originally Posted by RogerRamjet21
(Post 1598745553)
https://cimg7.ibsrv.net/gimg/www.cor...32871c1f77.jpg the C clamp is on the floor. |
To actually answer your question, yes.
Originally Posted by rjacobs
(Post 1598745296)
I noticed you're installing vented rotors. Is yours a Z51 also? I've got to get some rotors/pads. I can go with the OEM, ACDelco, or was looking at Centric rotors which appear to be good quality and are at a decent price. What route did you go? What pads did you go with?
Originally Posted by RobJoy
(Post 1598746917)
Do you remember the brand name on the parts or were they just AutoZone? How did they work out? Satisfied?
Do you remember the brand name on your pads and rotors? What do you think about them? Did they work out okay? How long ago did you do the brake job?
Duralast gold on the pads. |
(Post 1598747361)
Both work very well for street driving |
(Post 1598746917)
I think I have $380 into my setup on the GS, and I believe the Z51 stuff should be slightly cheaper. Rockauto was where I got mine from. |
For years I used c clamp. I finally bought some inexpensive brake tools from harbor freight. |
