Best polish
Hello, sorry for asking something that has probably been asked a million times. I bought a lemans blue C6 few months ago. I just ordered a random orbital buffer just now. Have couple questions. I have small swirls to fix but they’re not too bad. I want to fix that and have the best mirror shine possible. Can I use 1 kind of polish or do I need to get a swirl fix and then use a polish to shine? Whatever it is what is best for mirror like shine with using the buffer? Sorry for long winded thread just want to make sure I cover all bases. Thanks! |
I own a Inferno Orange 2012 Grand Sport that had 19k miles when I bought it.....
Overall a very nice car....but it did have a lot of fine scratches and tiny chips in the clear coat... I have a Porter Cable 7424 XP Orbital.....Ive had my best results using Meguairs M100 on a Meg's 6" Micro Fiber Pad. I recently bought a 3" Backing Plate and 3" Micro Fiber Pads as you can more easily get into around tighter areas I then finish my polishing with Meg's 205 on a White Foam pad and then use Black Fire Sealant and Im getting into using Black Fire SiO2 Sealant. Read www.AutoGeek.com and their detailing Forum for TONS of info. Im also using 3" 3M TriZact 5000 grit Foam Backed discs in my correction work Chuck Sharin Auburn, WA |
Adams polishes/waxes for me! Check out their website for some fantastic car care products
Originally Posted by Ladensack3
(Post 1598771171)
Whatever it is what is best for mirror like shine with using the buffer? Correction Microfiber cutting pads and 3D "HD Cut Plus" compound Green foam polishing pads and Poorboy's World "SSR-1". Blue foam polishing pads and Poorboy's World "Pro Polish". Protection/Appearance Black foam finishing pads and Poorboy's World "Black Hole" show glaze. Red foam finishing pads and Collinite 845 base sealant/wax Red foam hand applicators and Griot's Garage "Best Of Show" topper wax |
Check out these videos, they will be helpful to you.
Did you have a orbital polisher or a rotary? https://www.youtube.com/playlist?lis...-96Shcyb3VyUDy |
Orbital |
Fyrarms said it pretty well. You should start from a least aggressive method and a test spot. Gauge the type of correction/finish you would like to achieve from the test spot. Also note that you have an finite amount of clear coat to work with.
It's important that you seal,wax or ceramic after you polish the paint for protection. Whichever method you choose.
3D/HD One is a relatively new product, level of cut determined by pad. It's a nice, easy to use product, a bit oily on wipeoff.
May wanna try w/ an orange Lake Country Flat Pad or Thin Pro Pad to see if it will get your swirls out. Can then switch to a softer pad like LC White to refine a bit. If doing whole car and wanna do it all in one shot, best to have about 5-6 of each type of pad so no need to stop, clean and dry in the middle of everything. If your defects are deeper than that, Megs D300 w/ their microfiber cutting pads work pretty well, outcut Megs M101 w/ a yellow LC Foam pad on our black C5. Once you get into heavier stuff, microfiber pads better than heavy cutting foam...generally. About 100 ways to skin this cat |
Ok I was thinking of going with Adams correcting polish then going with finishing polish followed by a good wax. Is this a good method on a lemans blue 2006 vette with minor swirls? |
Hello, me again.
i got the Menzerna Heavy Cut Compound 400 with Lake Country HDO Orange Polishing Pad 3.5" for the most damaged areas, and the 3D one to use with Buff and Shine Uro-Fiber Microfiber Pad 5' for general fix. How can I fix remaining scratches like the one in the picture? https://cimg8.ibsrv.net/gimg/www.cor...b3d7364da4.jpg |
My amateur opinion is that you will need a more aggressive (micro fiber) pad with your MENZERNA
to remove the worst scratch... I used Meguairs M100 and JESCAR Corection Compound with Micro Fiber on my Worst Scratches and Clear Coat Chips..................... https://cimg5.ibsrv.net/gimg/www.cor...fb25799be6.jpg https://cimg8.ibsrv.net/gimg/www.cor...e42835ac30.jpg |
Hard to tell from that photo. You tell us. How deep is the scratch? Can you feel it with your fingernail? You can try a more aggressive compound and more aggressive pads, or try wet-sanding. If it is too deep, it is just staying there.
Originally Posted by FYRARMS
(Post 1602118001)
If it is as deep and persistent as you say...Might try bustin' out the sledgehammer...Megs 105 or Ardex Hard At It or Car Pro Clear Cut and a wool pad?
Originally Posted by H-Z/28
(Post 1602118995)
No, I can not feel it, just see it, and there are a lot over the car. Thanks.
I fixed this nasty C5 paint using the Meg's cutting disks and Meg's M100 compound. The Menzerna 400 should work just as well. https://cimg4.ibsrv.net/gimg/www.cor...75a2f51c68.jpg |
I juts ordered the microfiber pads, Let you know how it works. Thanks.
Rus what brand are those wheels, very tasteful dig the finish too. Classy
Originally Posted by cv67
(Post 1602121461)
@CamarosRus |
Loki6, You are too kind and amusing ..................
My Wheels are SIGNATURE SV701 with their BRUSHED FINISH and CLEAR Powder Coat They have many other Tinted Powder Coats as well Over the Brushed Surface ie Titanium, Black Tint, etc etc Wheels are mfg in Taiwan and currently take aprox 5 weeks to YOUR DOOR. I feel that SIGNATURE offers The Best Value in High Quality FORGED Wheels Contact me if you need more info than you can GOOGLE Search for |
