CXRacing Single Turbo "Street Car"
My old thread kind of got lost and a lot has changed since the last post I made so I figured it was time to start a new one. The car will be seeing lots of track duty and a couple of trips on public roads per year so according to an accredited "Corvette Historian" my car is a street car since it's not a tube chassis, balls to the wall "racecar." The goals for my build are 9 second 1/4 mile passes and 800-900whp on E85 but I'll also be running some 1/2 mile events once I get all the testing and shakedown completed.
Motor is a forged LS2 done by Mike Van Paris at the Race Engine Shop using K1 Rods, Wiseco Pistons and AFR 205 Heads. I've recently switched the CX Racing C6 hot side and I'll be fabricating my own up-is-downpipe, cold side piping, radiator/intercooler mounts and I'm sending my drivers fuel tank to Brett to have dual Walboro 450's installed in the next few weeks. The entire setup is run by a Haltech Elite 2500, Dual Wideband controller, I/O12 Expansion Module and a Fore Innovations FC3 to power the pumps. Setup will be tuned by Brett while I learn the ropes. The plan is to get her up and running by spring time, compete over the summer and then either paint or wrap the entire car next winter. Thoughts, criticisms, and suggestions are welcomed. https://cimg6.ibsrv.net/gimg/www.cor...645800c9f9.jpg https://cimg7.ibsrv.net/gimg/www.cor...215fae437f.jpg https://cimg0.ibsrv.net/gimg/www.cor...0d5a53c835.jpg |
Updated Mod List
Engine Ls2 Block K1 rods Wiseco Pistons 4.005" 9.5:1 GFX rings LS4 oil pump C6 oil pan Custom BTR cam AFR 205 heads LS9 head gaskets BTR pushrods Comp trunion kit ARP2000 head and main studs Elite chain drive LS7 lifters LS2 Intake Manifold Mighty Mouse PCV Can Mighty Mouse Draft Can Cooling System Griffin Radiator and Dual SPAL 10" Fans Redhorse Performance Thermostat Housing -20AN Coolant Hoses Fuel System RSI(2019) Dual Pump Hanger with Hellcat 525s Fuellab 8AN Inline Filter Redhorse 8AN Check Valve 8AN LS2 Style Fuel Rails FIC 127 LS2 Injectors Fore Innovations F2i FPR Fore FC3 Triple Pump Controller Haltech Flex Fuel Sensor Forced Induction CX Racing C6 Hot Side Comp Turbo CT43X 78/80 1.32 AR Twin Tial 44mm MV-R Wastegates Tial Q 50mm BOV Treadstone 1,000hp Intercooler 4" Downpipe with 2.5" Boost Activated Cutout LG Big 3 Catback Drivetrain B&M Shifter TMOD Lower Shift Box ZR1 TR6060 ME2 C6Z Diff with Coolers Hinson Swap Diff Mounts McLeod RXT twin disc Quicktime bellhousing Tick Clutch Master Cylinder Brakes/Suspension Viking SP Coilovers Wilwood Brake Prop Valve ABS Delete Custom Bent and Flared Lines to all 4 Calipers DBA Slotted Rotors Hawk HP Pads Stainless Braided Lines Engine Management Haltech Elite 2500 Haltech I/O 12 Expander Box Haltech Dual Wideband Gauge Haltech Dual Wideband Controller Haltech Racepak IQ3 Haltech Canbus Hub Haltech Terminated LS2 Harness Exterior/Interior C6Z Rep Wheels CCW Drag Pack Radioflyer SLC V3 Headlights Radioflyer LED Halo Taillights Corvette Creationz C Style Wing Corvette Creationz Carbon Fiber Wide Front Fenders 8 Point Roll Bar Lingenfelter Battery Relocation TigerShark Corvette Front Fascia |
I like this |
Build threads are always enjoyable. Looking forward to your "numbers", i.e., time slips from the quarter mile and speed slips from the half mile. :thumbs:
Will FIC 127’s supply enough E85 towards upper end of your HP goal ? I’ve got a large frontmount treadstone innercooler on my car from when it was on 93. Had I built my car from scratch for E85, chances are I wouldn’t use an innercooler. My innercooler blocks a tremendous amount of cool fresh air from my radiator and under the hood. I got my temps under control now but initially they were higher than I liked. I’d ask Brett what he thinks about ditching the innercooler on E85... |
Originally Posted by junk c5
(Post 1598801120)
https://cimg3.ibsrv.net/gimg/www.cor...1bbd80d34.jpeg Cross beam is completely hollowed out, IC support bar is welded straight to the frame rails. Radiator support is just like the IC support but is welded to 4”x1/4” steel plates that are bolted to the OEM rad cradle locations, radiator is sitting in RSM radiator mounts clamped to 1 1/4” DOM. https://cimg5.ibsrv.net/gimg/www.cor...6618715b2.jpeg Dual spal 10” fans with a fully enclosed shroud. https://cimg9.ibsrv.net/gimg/www.cor...5a09455e9.jpeg Catch cans. PCV can from the valley cover to the intake and a draft can off both valve covers https://cimg1.ibsrv.net/gimg/www.cor...9bc6c114b.jpeg Wilwood prop valve and bracket, just needed a slight bend to clear the inner fender. May replace the front line to clean it up but as of right now it fits and seals so Im not terribly concerned. |
Gotcha . It’s really close to the way mine is set up. I’ve got the biggest aftermarket radiator that would fit side to side and it’s mounted straight up & down. I also cut into my crash bar to mount my innercooler in a similar fashion. Also, I’ve got the twin spal fans which move an incredible amount of air. Additionally, I built an air deflector under the front bumper to direct air in front of the radiator. All together it cools pretty well. Naturally all the hot parts are wrapped and I’ve got a turbo blanket. The only reason I asked about the injectors is because I’ve got FIC 142’s running around 80% at only 700 RWHP on E85. Base Fp set at 58lbs. |
(Post 1598802064)
I have some FIC1650s i will be selling soon. If you are interested.
Now this is some quality content. I really like that CXRacing C6 single setup on C5s. Following with interest.
Originally Posted by algZO6
(Post 1598802488)
Nice build! I too am using the CX kit but much smaller goals due to financial reasons lol. I had to cut my crash bar too and welded up new mounts for the IC and rad. Looking great! |
That dash set up is sweet.
Originally Posted by Turpid porpoise
(Post 1598799418)
Originally Posted by Podium
(Post 1598807130)
Originally Posted by Capthuff
(Post 1598807849)
Ok.... so this looks pretty slick. Where did you get it? I had it custom made by a member of these forums. I think I still have his info somewhere if anybody wants to contact him. |
Yep... I want that in my life... |
Pm sent, I dont want to get him in trouble because he isn’t a vendor. |
Thanks. :thumbs: |
