What Holley carb is this on my '67?
Here's a photo of the Holley 4160 on my '67 coupe:
https://cimg8.ibsrv.net/gimg/www.cor...ae35323e44.jpg The numbers on the air horn are as follows: LIST - 1850 - 3 0320 I ask because the carb works fine, I had it rebuilt a couple of years ago. But, the fuel line is not correct. Instead of a steel line all the way to the carb, the PO used a piece of rubber hose to go the 'last mile' to the carb. I fixed a leak that sprung from one of the rubber hose clamps once already, and we all know how disastrous a fuel leak on a hot manifold can be! So, I ordered a repro steel fuel line from Ecklers and set about replacing the line. Alas, I discovered that the carb has no corresponding female fitting to screw the male fitting on the fuel line! :ack: This tells me the Holley on my car is not the original carb. It looks to be a service replacement. A friend tells me it is a Holley intended for a FORD, because the fuel line intake fitting is different than what GM used. So, can you tell me what application the carb on my car was intended for? Is it intended for a Ford? If I don't want to replace the carb, can I get the required fitting to connect the proper steel fuel line to it? Where would I find such a thing? Thanks in advance, -Alex |
its just a generic over the counter hot rod Holley
I had a replacement dated carb on my 67 L79 car (which a Corvette Hall of Fame inductee missed) and found the correct carb with correct date code and had it restored. Here are the photos:
https://cimg0.ibsrv.net/gimg/www.cor...4bdcbd3a1e.jpg https://cimg1.ibsrv.net/gimg/www.cor...b38bd986a7.jpg https://cimg2.ibsrv.net/gimg/www.cor...51708c8fc4.jpg https://cimg9.ibsrv.net/gimg/www.cor...28b3db17df.jpg https://cimg6.ibsrv.net/gimg/www.cor...7306cf94fb.jpg |
That is the cheapest, most generic 600 cfm carb Holley makes. Single feed, side hung bowls, fuel transfer tubes, secondary metering plate. Not a performance carb by any means. That said, they work fine for cruising and should give you years of trouble free operation. |
It seems that Holley doesn't sell a hard line inlet fitting for your primary fuel bowl. You can get a replacement swivel fitting and try cutting the hose barb off to install a compression union or similar coupling to plumb a hard line or find a replacement original style primary fuel bowl. If it runs well, you'd be better off getting some SAE J-30 specification fuel hose and smooth (not worm screw type) band hose clamps to replumb that section of hose.
I think you could use the Marine bowl Holley sells with the correct fitting. They sell a couple of fitting so you would need to verify fuel line fitting size to get the right one.
https://www.holley.com/products/fuel...rts/34R10918AQ https://www.holley.com/products/fuel...parts/26-27The The basic carb is fine for your engine. If may not be the high performance Holley line but it's still a very good carb and basically equivalent to what came with the engine originally. |
Also I don’t think that carb has a internal fuel filter. So you could run a 63-65 hard steel line into a stock filter and then a rubber hose into the carb. |
Alex, can't see from your photo, how is the choke connected (is it connected)? Factory set up used a choke rod from the carb. to a recess in the intake manifold along with the bi-metal spring & related parts.
Phil M. |
the carb shown in the first picture should have a cup shaped screen in the front float bowl to act as a filter
Originally Posted by Vettegeezer
(Post 1598804844)
Phil M. |
(Post 1598804727)
Also I don’t think that carb has a internal fuel filter. So you could run a 63-65 hard steel line into a stock filter and then a rubber hose into the carb. So, did Holley 1850's have an internal fuel filter? This was the case with the OEM Holley 3367/3810 carbs that were fitted to the 300/350 hp motors from the factory. Anything's possible, but whoever replaced the OEM carb would have considered the need for a fuel filter - I hope! |
Originally Posted by DansYellow66
(Post 1598804721)
https://www.holley.com/products/fuel...rts/34R10918AQ https://www.holley.com/products/fuel...parts/26-27The The basic carb is fine for your engine. If may not be the high performance Holley line but it's still a very good carb and basically equivalent to what came with the engine originally. Thanks for reassuring me that my Holley 1850 is a good carb. It certainly runs fine. I had it rebuilt last year and so far, so good. I could get a replacement Holley 3357A which is the correct carb for '67 with a 300 or 350 hp small block. These can be had for about $710. But, would I really notice much difference? Your thoughts? Back to the Holley 1850 on my car... In order to plumb the OEM hard line direct to the carb, would I have to replace the front fuel bowl with one that has a female fitting? Or, can I screw in an adapter of some sort to allow the OEM hard line to be connected to the front float bowl on the carb I have now? |
I posted above this screen should be in the fitting. https://www.walmart.com/ip/Holley-26...&wl13=&veh=sem
I don't think I've seen an L79 with the metal line all the way to the carb.
The L79 used hard line all the way to the carb. The filter was in the carb:
https://cimg7.ibsrv.net/gimg/www.cor...45114fe646.jpg GM didn't use rubber hose on the pressure side of the fuel system. For good reason. Lars |
Originally Posted by lars
(Post 1598819591)
Lars https://cimg0.ibsrv.net/gimg/www.cor...086f13d926.jpg |
Originally Posted by Mr Fufu
(Post 1598819369)
Hi Dan,
It won’t look exactly factory, however this banjo with a 5/16” tube... https://www.summitracing.com/parts/sum-g3144/overview/ ...can be used with this compression fitting to join the hard line from the fuel pump to the carb. https://www.summitracing.com/parts/rnb-800-142 Simply trim the end of the nipple off the banjo tube and use the double compression to join the hard line from the fuel pump. For less than $20 you are done! BTW, I didn’t mean to imply you carb is “no good”. It is an excellent and reliable carb. It just lacks the performance upgrades that make it a true performance carb. |
Originally Posted by 65GGvert
(Post 1598819596)
Was that the case with 65 L79's also? I've only owned 65's that had that engine. This is the one I have now, is it incorrect? (2818-1 with external filter)
Originally Posted by Factoid
(Post 1598821135)
