A/C question
OK, so I have an 88 C4 and of course the A/C doesn't work and the system was the old R12, I am going to convert it to R134A and need to know how much R134a I need and are there items I MUST replace.
and just to kiss ass I KNOW YOU GUYS/GIRLS can help :) |
You'll need to investigate the details, but my understanding is that there is a direct (and cheap) R12 replacement with no changes to the system.
I put in 3 12 oz cans and +6 ounces of r134 into my conversion. But it won't take it unless a vacuum is pulled. Which you really should do for 45 min anyways to evac the system.
Still working after 1 1/2 years. |
A/C question
I changed my system to R134A about 5 years ago it's been working great I had my compressor rebuilt, then I just flushed out the system real good. The auto parts places will rent the gear you need. You must change out the dryer, the schrader valves and the orifice (expansion valve). The orifice has different colors which have different size openings. The smaller the opening the colder the A/C will be.
You have to evacuate the system and leave it in place over night to verify no leaks. My 1990 Vette would set a ECM error of low refrigerant that has to be cleared before the compressor will run. I found that the gauge set from the auto parts place barley work so I just added R134A till the compressor would stay running the determined my vent temp by how hot it was out side. It still working. The way I filled it was with a thermometer in the AC vent (meat thermometer works best). You then add refrigerate until the correct temperature appears on the thermometer. There is a chart on the internet that tells you how to make this measurement. You check the temperature at the condenser and that will tell you how cold the thermometer will go. you have to add more R134A than the old refrigerant. Ray |
You might also add a little yellow leak detector fluid if not included in the R134A used.
You'll want to replace the receiver/dryer and install the new fittings. A good 15 or so minute vacuum on the system with an a/c machine will help to remove all of the R12. After that you'll need 2 pounds 12 ounces of R-134 and 1 ounce of oil.
This stuff goes in the stock system with no extra modification:
http://www.redtek.com/products_refr.html Blowing cold and working great on two different cars after 6+ months (3 during the summer). Once it gets hot again I'll let you know if it's still going, but honestly a can to recharge every year isn't a big deal to me. |
Originally Posted by jagvette
(Post 1598818536)
and just to kiss ass I KNOW YOU GUYS/GIRLS can help :) What are you changing? Compressor and Receiver/Dryer at the least. You have to change all the O-rings. I changed all the hoses too. I'd flush it but I would never fill it in my garage. That I get a shop with the right equipment to do. |
I agree. My R12 setup was colder. A couple of years ago I bought a bunch of cans at a swap meet. Worth every penny. I would still have that setup if my compressor had not blown up.
I still recommend the Redtek product. Guy I bought my car from had it recharged with r134a and complained it didn't work. I was worried something might have been ruined but I just vacuumed the system and added the Redtek, and it's still going strong. I tested in 70 degree weather yesterday and it was cold as ice.
(Post 1598818536)
and just to kiss ass I KNOW YOU GUYS/GIRLS can help :) I converted my 85's R12 system to R134a close to 3 years ago, new compressor, accumulator/dryer, orifice tube, cycling switch, etc. I did it by the book -- no regrets. still working without issues. center duct temps around 40° at cruise, and around 55° in stop and go traffic. these temps are with 90° summer days here in florida. if you're serious about the conversion, start here... https://cimg2.ibsrv.net/gimg/www.cor...191bbf2377.jpg then again, there are folks that have had success with the $39 Wal-Mart, conversion in a can method too -- depends on how you want to go about it. :thumbs: |
Originally Posted by Joe C
(Post 1598827912)
for the conversion, you need, obviously, the high pressure/low pressure port adapters to charge the system, and R134a compatible O-rings. you should install a NEW accumulator/dryer, drain the compressor, and i'd flush the entire system. ideally, it would be nice to install a new compressor, but in your case, that's a big ticket item, so drain and flush at a minimum. the oil used with R12 is not compatible with PAG oil used in a R134a system. i'd switch to ester oil which is compatible with both systems. my understanding is you should try to get 95% of the old oil out of the system, which is why you should flush the system. replace the orifice tube, and I recommend going with a .067 vs (i'm thinking) the stock .072 orifice tube. you will also need to replace the low pressure cycling switch. a functioning R134a system will use approximately 85% of the freon required in a R12 system, however, it all pressure related and dependent. tools and equipment, you'll need a vacuum pump, and a manifold/gauge set.
Originally Posted by aklim
(Post 1598828189)
How did you do the switchs? I had to scrounge for NOS since they did not have it at FJC
(Post 1598818536)
Mine was r134 when I bought it. Needed some refrigerant last year. The R134 works fine and gets plenty cold.
These were taken after work. Took about 3 miles in light city traffic to achieve these temps. https://cimg8.ibsrv.net/gimg/www.cor...9f878e5b48.jpg Outside https://cimg9.ibsrv.net/gimg/www.cor...5162021c00.jpg dash vent at starup https://cimg7.ibsrv.net/gimg/www.cor...49fa7b24ae.jpg final output temp |
Originally Posted by belairbrian
(Post 1598840820)
These were taken after work. Took about 3 miles in light city traffic to achieve these temps. Outside dash vent at starup https://cimg7.ibsrv.net/gimg/www.cor...49fa7b24ae.jpg final output temp |
(Post 1598823059)
Originally Posted by gpierce
(Post 1598844053)
I have heard people say this before, change all O-rings. I have also read that it's OK to leave any O-rings that are not leaking, but replace the ones on anything you open. I have always done the latter with success. Changeed the ones like on the dryer, and compressor (if I replaced or removed it) but left others alone unless it was leaking from them, Has worked out on all the cars I've done a conversion to.
