***Radioflyer's "Luminator" Low-Rise Headlights GP!!***
After working out the kinks, we're proud to announce the re-release of the definitive low-rise headlight solution for the C5 corvette. The Radioflyer "Luminator" Headlight system uses dual Hella 60mm projectors and HID/LED light sources to provide stunning appearance and equally impressive performance. The Lifting arm issues have been remedied by replacing the aluminum components with steel and the shrouds will now be made of cast urethane (same as the front bumper) instead of 3D printing for nice smooth finish and ease of production. (no more 3D print lines)
https://cimg0.ibsrv.net/gimg/www.cor...e9ff1121c4.jpg https://cimg1.ibsrv.net/gimg/www.cor...4138eb4de9.jpg https://cimg7.ibsrv.net/gimg/www.cor...ab2e505568.jpg Low beam: No glare to oncoming traffic https://cimg7.ibsrv.net/gimg/www.cor...7005fa57cc.jpg https://cimg7.ibsrv.net/gimg/www.cor...4c266782ec.jpg Low beam only (one side) https://cimg5.ibsrv.net/gimg/www.cor...0876be4440.jpg Low + High beam (one side) https://cimg5.ibsrv.net/gimg/www.cor...3f45a5e926.jpg A few questions I'm often often asked: Q: How does it perform compared to our other headlight systems: A: The low beam total output is the same, but the pattern is a little narrower and the step a little higher. While there is no "dual-function" projector, the dedicated high beam projector features a 3000 Lumen LED light source that really turns night into daytime. Q: How do you change the lift of the headlight? A: The headlight lift is changed by the included lifting arm assembly which has slightly different dimensions from the factory arms. No permanent modifications (drilling/cutting) to your headlights are required Q: Can the shrouds be painted? A: Yes, the Shrouds are the same type material as the front bumper and can be painted to match the car or a textured black to mimic the factory ABS look. The GP price will be a slight discount off the normal price and will last through Valentines Day at which point I will begin ordering the minimum parts needed for this GP. Order here: https://radioflyerinnovations.com/sh...dlights-for-c5 |
Very interested! Clicked on the link, nothing came up. Please let me know how I can get in touch with you to get a price and a deposit going.
Thank you |
Originally Posted by arthursc2
(Post 1598828344)
Thank you |
Just my luck that this was upgraded and re-released right after I purchased and installed your Bi-Xenon ACAs :(
Will the new design satisfy the "headlight jiggle"? I have the ACAs which jiggle. Thanks
I need the new shrouds. How do I get them? |
Originally Posted by AE Guy
(Post 1598829524)
Originally Posted by DNAST1
(Post 1598830058)
Originally Posted by lewislgZ06
(Post 1598830089)
hmmm, as in interested.
Bump.
afternoon bump
I know it would be a pain, but I would really like to see a side-by-side of stock versus low-rise, possibly a mid-install with one light open to stock height and the other at the low rise. I see the low rise height, but without a reference I have trouble visualizing just how low it is.
Originally Posted by redzg
(Post 1598844717)
https://cimg0.ibsrv.net/gimg/www.cor...cc5e9d520a.jpg If i recall, there is about a 2.5" total rise difference at the inboard corner. |
Stock rise height is 6 3/4 if I remember correctly offhand. I believe radioflyer has his set at 4" when open. It is noticably lower both inside and out. I don't own a set but have been working on my own set that is similar. Those are just measurements I remember off the top of my head, don't quote me on it.
4 more days for this special pricing!.
two more days for special pricing.
The shop making the shrouds has indicated they needed a little more time than anticipated to prepare the tools to make the shrouds. The first batch of shrouds is scheduled to be finished by the first week of March. Apologies for any delays. I will keep everyone up to date here. Everything else is on schedule.
Update: Shroud master molds have been completed. Urethane casting is underway. Here are photos of the master molds. Notice how smooth they are.
https://cimg0.ibsrv.net/gimg/www.cor...872d235c74.jpg https://cimg6.ibsrv.net/gimg/www.cor...da11209f9d.jpg https://cimg8.ibsrv.net/gimg/www.cor...d2667a4af9.jpg https://cimg1.ibsrv.net/gimg/www.cor...3c753ac9b3.jpg |
Yes, finally! This is awesome
Great news! Just got the first batch of shrouds from the shop and they are AWESOME. They are even more sturdy than factory and unlike previous versions there are absolutely no "print lines". The shop suggested using a primer coat before paint. Customers seeking to paint-match will find the surface already just as smooth as body panels with no sanding needed. (see photos)
I expect all current orders to go out Tomorrow!!! https://cimg2.ibsrv.net/gimg/www.cor...0dc7c69c2e.jpg https://cimg3.ibsrv.net/gimg/www.cor...355b76eb01.jpg https://cimg4.ibsrv.net/gimg/www.cor...56b1474f5b.jpg |
Order placed for the new shrouds. These look more like the quality I’ve come to expect from your products. I only wish I had waited for these shrouds to be produced before purchasing the luminator low rise light kit. It would have saved me a lot of $$$
