C8 base performance, like C7 Z06 since C7 base was like C6 Z06 performance?
It seems the next generation base corvettes have about the same performance as the previous generation mid level corvette, so since we have nothing better to do in this section but speculate... I think the base C8 will be 0-60, 60-0, 1/4 mile et/mph and lateral accelerations will be about the same or slightly less than the C7 Z06. While I am at it, the base C8 will be $65k. Your turn. Play nice!
I like your thinking. If the price/performance is close to your prediction, I don't see how GM will keep both C7/C8 production lines open, as some have speculated. The C8 will be on perpetual back-order.
Your within a very reasonable range on all your predictions....
But,unfortunately that didn’t sell well around here.... Put on your best flame suit. |
Following your logic which i happen to agree with based off of the past three generations i believe the standard c8 with heavy duty coolers and suspension aka z51 will have performance that slots between the c7 grand sport and c7 z06.
braking and handling will be near equal to the c7 z06 and acceleration will slot between the c7 grand sport(3.7 seconds) and c7 z06.(3.0 seconds) . We should with the dct and rear mid engine weight bias be able to see zero to 60 mph in 3.3 seconds. of course we are just guessing but thats my estimation as well. a few months and GM will give us factory performance numbers. one interesting fact of having a dct everyone will be able to match GM performance accelleration specs. |
What are the numbers for a C6Z06 vs C7 Stingray? I don't think they are that close.
Actually the c6 z06 and the stingray z51 were extremely close. (Acceleration within .2ths of a second to 60mph and in the quartermile)
Originally Posted by JerriVette
(Post 1598839265)
I think we would have to set up both cars with same tires to compare.The C6 Z06 had the Goodyears which just aren't as fast.
Originally Posted by Philr56
(Post 1598839182)
FE goes 60k-130k ME goes 80k-170k Life cycles of the variations overlap to allow for design, development, testing, etc. |
Originally Posted by range96
(Post 1598839302)
Not really. The 7L, high revving LS7 was hard to beat for performance. The problem was to keep it in one piece. The C7 was a better handling car, I agree.
Originally Posted by warhawkmcdaniel
(Post 1598839333)
you pretty much answered the question... close enough. |
Porsche GT3 has 500 hp and does 0-60 in 3.2. The advantages of having weight over the driven wheels and a great transmission.
If done right, the base ME will be very close to the C7 Z06 in performance. |
(Post 1598839302)
Originally Posted by pietro c7
(Post 1598839233)
Originally Posted by ffr1352
(Post 1598839058)
Quite likely. The C8 has the advantage of being ME, so a more modest power increase is required to achieve C7 ZO6 acceleration performance.
Rumors suggest a base 500+hp LT1 variant, but based on my own intel there is something more to the powertrain that is being hidden even from GM suppliers who would normally know at this point in development. |
Originally Posted by OnPoint
(Post 1598840626)
Originally Posted by jschindler
(Post 1598841178)
There are two ways to look at that comparison. Yes, you can show much better 0-x times if the car hooks up from a dead stop better. But accelerating through the gears from a roll is what is real world. Only drag racers and bench racers benefit from a dead stop launch. I’m not saying it’s a bad thing, just that it is only one aspect of the performance measure.
(Post 1598841178)
0-60 (or 0-x) often has carried way too much weight. I think that is because the general buying population can early wrap their heads around 0-60 times. But now, with top performance cars all clustering around that 2.x-3.x second range (in 100% ideal road situations), that performance measure has all but lost its meaning. Performance from a 40-50mph roll is really what I find more interesting. |
I think if the price increase is higher than usual for a next gen (say 70K), I think it comes with 510-515hp. I think if its $60-65K it is 495 or 500hp...
With DCT and ME layout, I think 0-60 in 3.2/3.3 is definitely the target area... maybe they surprise us and its 3.0 |
