l98 MAF sensor tester
Anybody have a MAF tester laying around, or anybody know an easy way to test a MAF in a 1985 corvette
Did not mention the issue you are dealing with.
Just in case, I thought I had a bad MAF as that is what the factory manual fault logic told me. I got a replacement and issue was not resolved. Guy on third gen.org suggested I check my throttle position sensor, problem solved. This was a 350 tpi IROC, 1988. I do do have two that worked but has been awhile. One with screen and one with screen removed. |
