Stalling
I overfilled the gas tank a week ago. After driving the car for 10 miles it stalled. I opened the gas cap and pressure was released. After 15 minutes I drove it home. Today I took it out and after 15 minutes it stalled. I opened the gas cap and the same thing happened. After 15 minutes it started and I drove it home. New the service soon light is on. It has 41,000 miles on it. Any thoughts on gas cap or other causes?
Did you notice pressure release before you had the problem? When you filled the tank before? What year? OBD2 will set a code for fuel cap. I'd replace the cap and clear the codes. Just pull the ecm fuse for a couple of minutes. You could also let autozone pull the codes and go from there.
Hth, Joe K |
According to one of his earlier posts, it is a 1993, so OBD I.
Originally Posted by Ronnie123
(Post 1598847961)
(Post 1598847961)
Stalling
From what have heard from the C4 forum is that if try to squeeze as much as you can in it can cause liquid to get into the charcoal filter causing pressure to buildup and the fuel pump cannot overcome the pressure.
(Post 1598852095)
(Post 1598852095)
(Post 1598852095)
OP why haven't you pulled the code to see what the car is trying to tell you the problem is? That would be "step 1", here. |
Stalling
Which code reader would you recommend? I put a new gas cap on it and ses light went off. Drove it for 30 minutes today and no issues. It has 41,000 miles on it. It is a 1993 LT1.
I'd recommend none. I'd use a paper clip or jumper wire to jump the terminals in the ALDl connector under the dash, then count the flashes to get your codes. See this 'how to', HERE
(Post 1598852577)
Stalling
Started 10 minutes ago SES back on. Idling at 1500 rpms.
Taking it to a Corvette specialist unless I get a better suggestion. Frustrating as it was my brother in laws since new. It is in near showroom condition but 26 years old.
Originally Posted by aklim
(Post 1598853208)
Cheap paper clip or a real scanner. Real scanning will give data which the code scanning will not. That comes at a price but saves aggravation. No free lunch.
Stalling
Is there some sort of pressure relief valve on the EGR or other emission system that may cause it. I would love to learn how to perform my own repairs.
Have not worked on cars since I restored a 1972 Trans Am in 1982. |
Here is another link for reading the codes with a jumper wire (paper clip). On your 93 it will actually display the numerical trouble code directly, no need to count flashing ses lights. Check the code before making any guesses.
https://tech.corvettecentral.com/201...trouble-codes/ |
Stalling
The frustrating part is we driven the car for a 100 miles at a time over the 7 months we have owned it. This started 15 minutes after fueling it. Can the fuel pump operate effectively and then not and then operate effectively again?
(Post 1598853540)
Stalling
There is no issue on operation at all until 15 minutes of driving. Acceleration is awesome.
https://cimg3.ibsrv.net/gimg/www.cor...48376557b5.jpg https://cimg4.ibsrv.net/gimg/www.cor...975da80847.jpg it won this award too. We would like to keep it the family as my brother in law passed away last June. If the diagnosis is daunting would you recommend I take it to a professional? |
What is happening at 15 minutes? Fuel pump not working? Oump not getting power? Spark from opti? ECM? If it dies and can restart, rap the ECM and see what happens. It might be the cold solder pieces of solder. It could be the opti failure when hot. It may be a Oump dying when hot, it might be the power to the pump.
Stalling
After 15 minutes of driving it stalls
If you try to start it tries and stalls immediately. Wait 20 minutes and it starts |
(Post 1598853806)
