Weapon X Meth Kit installation time
My question regarding the Weapon X Meth Kit installation time has been answered.
Anyone install the Weapon X Meth Kit? If so, how long was the install? https://weaponxmotorsports.com/colle...t=406141730843 Thanks! |
I wouldn't even think about using that kit on a c7. I've actually never seen that kit on a c7. Alky is the kit to buy for a c7. Takes about 6-8 hours to install.
The C7 you just use the washer tank so there is no need for a tank in the trunk. |
Sounds like you don't really know.
There is nothing wrong with this kit and I honestly prefer to have a separate tank to be able to finely control what is being injected into my engine. |
Originally Posted by subieworx
(Post 1598857285)
There is nothing wrong with this kit and I honestly prefer to have a separate tank to be able to finely control what is being injected into my engine. My point here is I have NEVER seen this kit on a C7 EVER... Not trying to bash the system at all, it's just not something I would remotely consider. If you need meth to be injected into each cylinder for fueling then you need to just invest into a real port injection fuel system. |
Originally Posted by C7&7
(Post 1598857455)
How does a separate tank allow you to finely control what gets injected into your engine?
My point here is I have NEVER seen this kit on a C7 EVER... Not trying to bash the system at all, it's just not something I would remotely consider. If you need meth to be injected into each cylinder for fueling then you need to just invest into a real port injection fuel system. On the kit that C7-7 is telling you to use here the washer tank is mounted high so it is running down hill all the time that is feeding the pump & this distance from the pump & the tank feed line is really a few inch's.. Your car do what you want WEAPON X is a great shop I am sure they have do the R&R on the system but C7-7 is just telling you here the other kit has been out here & has been working from the c5 & c6 time here.. Robert |
Just get Julio Dons kit for c7 and be done. Specify single or dual nozzle, put the pump controller in the kick panel and put the test/adjust module in the radio cubby. Get the DSX IAT breakout harness and sensor. I’m all in in less than 5 hours...
