2019 Z06 junk in the trunk?
I have a 19 Z06 convertible on order. I was looking at an 18 on another dealers floor and there were quite a few pieces that were in the trunk of the car that would be included/installed at delivery time. I recall brake cooling ducts, the fuel fill tube and 2 front license plate holders. Are there any other items that are normally included? Tow hook? Any thing else I should be looking for?
Just curious so that the delivery setup guy doesn't get any "trophies" that should be in my possession when I get the car. |
It depends on the trim level and aero you ordered. If it's a Z07 convertible, there are additional track items such as the Stage 3 front side spears and the rear spoiler wicker bill. My dealer installed the track brake ducts as well.
If you did order Stage 3, make sure the PDI tech returns the lower Stage 2 front splitter side spears. Also, if you have ceramic rotors, you should have some rotor foam pillows that protect the rotors during maintenance and when wheels are removed. Your owners manual will also be in the rear cubby as well as the fuel fill tube. No tow hooks are provided for U.S. cars so you will have a place to store it, but no tow hook. |
My 18Z non-vert non-Z07 came with track brake ducts in trunk. My 19 same car came with them installed. There is actually a TSB or recall that would install the street brake ducts and give me track ones in trunk.
Mine came with:
- front plate mounting kit - oil filler tube - metal backing plates for brakes - plastic brake ducting - battery tender - cargo net - cargo shade - owner's manual, supplemental manual and XM radio booklet - front car matts - build sheet and all plastic bags from shipping - car's sticker (never attached that I could tell) |
