1985 Doug Nash 4+3 $800 OBO
I'm selling the Doug Nash transmission out of my 1985 manual Corvette. The OD unit needs a new clutch pack as they have burned up, otherwise it is in good condition. The T10 has a crack in the aluminum housing that will need to be repaired.
The T10 portion of the transmission was in a wreck which caused the crack. Before the wreck I had no issues from it and would suspect it to be in good shape of you are able to repair the crack. The OD is from my current car, the clutches went out on it and I had a working OD from the wrecked car, so I swapped them out as it was cheaper than rebuilding for me. I'm in the Nashville area of Tennessee so if you're local to that area that's a plus. |
