2019 engine tick
Wanted to run this by some people that have experience hearing these engines run or may have heard this before. I spent a few afternoons searching the forum for similar issues and there are a ton of threads complaining of engine noise so I'll apologize up front about starting another. I'm aware of the normal direct injection associated noise these motors make and I will be taking the car in to cover those bases.
Anyway, car has 30 miles and has been run up to temp twice. Engine temp, load, speed don't seem to make any difference in the noise. It's loud enough it sounds like a large exhaust leak at the passenger floorboard when driving and the radio doesn't cover the noise, its pretty loud and is present at all times. Oil level is fine, idles smooth, no stumbles or check engine lights so far the car runs strong in my brief experience with it. Based off my research it seems like the frequency and regularity of it would point to a valve train issue but please correct me if I'm wrong. To me it sounds like excess lash in a rocker which I guess could be caused by a short lifter, bent rod, loose rocker, etc. I have read the fuel pump in these things can be pretty noisy but remember reading it pulses 3 times for every one cam rotation so I think this noise is too slow for that? It is more pronounced on the rear passenger side but it's tough to tell if it's in the valley or not, the fuel pump is located there correct? Thanks all, links to videos below. |
Definitely sounds like a valve train issue to me. We just dealt with a bent push rod on an old Mopar that sounded just like that. I would have it towed to the dealer and let them deal with it.
its got 30 miles,either drive the crap out of it,or take to the dealer
Originally Posted by dmaxx3500
(Post 1598853775)
Sounds like a knock and not normal.
Sorry to hear about your misfortune. Hopefully you get it resolved soon and are enjoying many miles and smiles to come, good luck.
Originally Posted by z06inVB
(Post 1598853669)
Agree, call dealer and then have if towed there. Hopefully simple like pulley. Good luck and pls let us know. |
Have you run it in eco mode? Is it a manual or auto trans? Sounds like a sticky lifter to me. With those miles I'd let them take care of it (it's not normal injector/pump sounds).
Keep up posted bud! |
I was ready to tell you that it's a DI engine and they all tick, but what you've got there is definitely broken. Back to dealer.
Originally Posted by devnull
(Post 1598854473)
Keep up posted bud! Car is a manual so no V4 miles as far as I know unless it was in the first 4 miles. Both times I drove it was a mix of tour and sport. Thought about taking it out and getting into V4 mode and then back out to try to cycle the valve train but decided to not drive it. It definitely sounds like there is slack in a tolerance that is being taken out and the tick is metal parts coming together. Just like a short lifter being smacked into a rod as the gap between them is taken out by the cam lift. All speculation of course. If the lifter is collapsed it can't be completely because the car seems to run fine. Otherwise there would an intake or exhaust valve not opening on a firing cylinder right? |
Originally Posted by Thunder22
(Post 1598854759)
(Post 1598854473)
That sounds awfully familiar, sorry you're having to deal with this. This was my failed lifter... they ended up doing a complete rebuild.
Originally Posted by DopplerGS19
(Post 1598855034)
I've tried responding but my replies are being auto moderated. Car is a manual only had it in sport or tour both times I took it out.
Sorry about the hassle, it stinks on a new car! |
Originally Posted by HooosierDaddy
(Post 1598855160)
https://www.youtube.com/watch?v=_sCcfqFAUc8&t=2s. |
(Post 1598855160)
Also since this section gets more traffic than the regional if anyone has a recommendation for Corvette service in or around Columbia, SC I'd appreciate it. I'm considering taking it to Charlotte but we'll see. I have zero experience with any dealers around me.
(Post 1598855190)
DANG! That one was severe! How has it been since the rebuild? What exactly did they do?
Other than the stress/worry of a new car having this issue, It was a positive end result and I'm happy with the level of service the dealer provided. |
(Post 1598855246)
It's definitely not that severe but I don't expect it to improve. At this point I'm just hoping whatever work gets done is proper and the car comes back in decent shape considering it was unwrapped 4 days ago. The first 30 miles had me really looking forward to more barring the tick it's a fantastic car.
(Post 1598855335)
Get a Range Device for it. This lifter problem is related to cylinder deactivation.
