Holley's new 2-Piece Aluminum Valve Covers (Hides Coils) >
1 Attachment(s)
I was really interested in the new Holley 2-Piece valve covers after one of our forum members ("hmmmm16417") stated that he was going to purchase a set of these.
The lower section of the valve covers obviously function like normal valve covers and isolate the oil from the top of the heads, but the upper section of the valve covers hide the coil packs and associated wiring. These covers come in various colors. Here is a link to the uncolored aluminum finish https://www.summitracing.com/parts/hly-241-170 They are pricey at $450 per set, but they would sure clean up the engine for anyone that is considering removing there OEM fuel rail covers. In my case, since I have a top-mounted blower on my GS, I can't use the OEM fuel rail covers anymore, so these new 2-piece valve covers would really be just the ticket for me. _______________________________________ Here is a photo that the forum member posted awhile back, with these new valve covers installed on his engine: https://cimg8.ibsrv.net/gimg/www.cor...7b6334e052.jpg Here is my engine now with just the standard Holley "Tall" aluminum valve covers installed .... Not bad, but I think it would look better if the coil packs were hidden: Attachment 48336178 What do ya all think ? |
I love the look...Would be better if we had choice of marking...
Originally Posted by hawkgfr
(Post 1598857898)
.... Would be better if we had choice of marking |
Those are nice.
Look into this conversion. Cost a little more, but I think it’s better because you can pick whichever style SBC valve cover you like versus being stuck with the Holley design.
http://www.billetspecialties.com/ls-...nversion-kit-/ |
Just an FYI, they are NOT a simple bolt on valve cover. the driver side was a PITA!
1. the valve cover hits the alternator, so you have to extend the top bracket of the alternator to get it to fit. You also have to grind out some of the bottom alternator bracket. 2. I had to cut the bottom of the cover so it would go on since there is no room to feed the angled coils out of the holes (see blue lines on pic below) - passenger side wasn't bad at all - no mods needed 3. if you want to maintain the safety brackets that prevent rails from popping up in the event of an accident, you have to modify them to fit around the cover (PITA) 4. There is no oil fill cap on the outside, so you have to pull the coil cover to fill the oil....and they are on the firewall side 5. as I was installing them, the red paint was starting to flake off where the lines and "holley" is machined. not real noticeable unless you're looking for it, but for the price I was not Happy one bit. Unfortunately, I had already modified them before I noticed. Edit: I'm not sure your fuel rails would clear, it would be close. https://cimg0.ibsrv.net/gimg/www.cor...4b76f8b194.png They don't look bad, and I'm debating if relocating the coils would have been easier...... not sure. It's definitely a unique look and I can guarantee no one else in my area has them. hahahaha I'm still working on the final version of my alternator bracket. Luckily I have the chrome shield cover that hides the modified bracket. |
Originally Posted by hmmmm16417
(Post 1598861925)
1. the valve cover hits the alternator, so you have to extend the top bracket of the alternator to get it to fit. You also have to grind out some of the bottom alternator bracket. 2. I had to cut the bottom of the cover so it would go on since there is no room to feed the angled coils out of the holes (see blue lines on pic below) - passenger side wasn't bad at all - no mods needed 3. if you want to maintain the safety brackets that prevent rails from popping up in the event of an accident, you have to modify them to fit around the cover (PITA) 4. There is no oil fill cap on the outside, so you have to pull the coil cover to fill the oil....and they are on the firewall side 5. as I was installing them, the red paint was starting to flake off where the lines and "holley" is machined. not real noticeable unless you're looking for it, but for the price I was not Happy one bit. Unfortunately, I had already modified them before I noticed. Edit: I'm not sure your fuel rails would clear, it would be close. https://cimg0.ibsrv.net/gimg/www.cor...4b76f8b194.png They don't look bad, and I'm debating if relocating the coils would have been easier...... not sure. It's definitely a unique look and I can guarantee no one else in my area has them. hahahaha I'm still working on the final version of my alternator bracket. Luckily I have the chrome shield cover that hides the modified bracket. Hero update...thanks! |
Originally Posted by ttx350z
(Post 1598859299)
http://www.billetspecialties.com/ls-...nversion-kit-/ Those are very interesting...wonder how the coils hold up trapped like that. |
(Post 1598862464)
i too wonder how the heat is going to affect the coils.
Originally Posted by jior
(Post 1598862635)
Don’t hide the coils...
https://cimg8.ibsrv.net/gimg/www.cor...c9e4f7094.jpeg |
Originally Posted by grady
(Post 1598862900)
(Post 1598859299)
Well, I am very disappointed in that the Holley 2-piece valve covers need to be cut up like that to make them work. Not to mention the fact that the alternator bracket also needs to be modified.
For the price of these Holley valve covers, you would think that Holley would manufacture them so they would not need all the additional fabrication. Jeeeze ... Don't these companies even try these parts out on various cars before selling them to the public? Well, I will pass on these valve covers! A big thumbs-up to "hmmmm16417" for posting a very good review of the problems he encountered :thumbs: . |
Originally Posted by Turbo6TA
(Post 1598895676)
For the price of these Holley valve covers, you would think that Holley would manufacture them so they would not need all the additional fabrication. Jeeeze ... Don't these companies even try these parts out on various cars before selling them to the public? Well, I will pass on these valve covers! A big thumbs-up to the OP for posting a very good review of the problems he encountered :thumbs: I'm probably going to send an email to let them know |
(Post 1598862483)
(Post 1598895676)
For the price of these Holley valve covers, you would think that Holley would manufacture them so they would not need all the additional fabrication. Jeeeze ... Don't these companies even try these parts out on various cars before selling them to the public? Well, I will pass on these valve covers! A big thumbs-up to "hmmmm16417" for posting a very good review of the problems he encountered :thumbs: . Coils don't like heat, so for that reason alone I would skip these as it can't be good cooking the coils like that. |
Ugh, I was digging these two piece valve covers until I found this thread.
They look good, but to me, they are kinda out of place on a newer Corvette with a black plastic intake between them. They would look great with a tunnel ram between them in a C3, T bucket, or older muscle car though. Paint them black instead of red, and they'd look better IMO.
