Willcox C3 Clearance Item Thread 2019
I'm starting this thread so you guys could have a heads up on the stuff we're cleaning out of stock. I will add items to this as I get more links up.
So here we go. 76-77 CORVETTE SMOKE VISOR SET CLEARANCE ITEM. 1 PAIR Corvette Original Rear Strut Rod Inner Mounting Bracket 1968-1974 RECONDITIONED 63-82 CORVETTE FRONT A-ARM SHIM CORRECT STYLE. USA MADE! CLEARANCE ITEM 75 76 77 78 79 CORVETTE LICENSE PLATE BRACKET MOUNT 63-70 Corvette Transmission Spindle Yoke 26 spline 3868728 63-82 CORVETTE REAR SPINDLE KNOCKOUT TOOL KNOCKER TOOL. 77-82 Corvette Visor Rod Set 77-79 early original See lower detail. I'll be adding more soon. Willcox |
TTT for an AWESOME Vendor!
Bump
Corvette Ignition Top Shield. 1968-1970 (1970 Early Cars Only)
Corvette Rear Trailing Arm Spindle Dust Shield 63-82 63-82 CORVETTE REAR TRAILING ARM BUSHING KIT EA. 73-75 Corvette, 70-72 Chevelle NOS Hood Emblem 454 339116 CLEARANCE ITEM 1968 CORVETTE Corvette LH & RH Front Inner Fender A-Arm Seal Flap Pair CLEARANCE 68-75 Corvette Weatherstrip Fastener Kit NEW Convertible Top CORRECT! 34109B |
Is the 26 spline yoke for a munci 4 speed?
Yes
Few more items today. Got busy working the C4 and C2 stuff today.
63-67 68-82 CORVETTE A-ARM BUSHING SET UPR AND LOWER |
67 68 69 CORVETTE 427 HOOD EMBLEM CAR ST NEW INCLUDES NUTS.
78-82 84-96 Corvette Fuel Tank Hose Fitting "Gas Tank Fitting" 58-66 70-81 Corvette 90' Fuel Pump Fitting 1/4" Thread, 3/8" Tube Size 1978 Corvette Sales Brochure NOS Original 1976 Corvette Sales Brochure NOS Original 1975 Corvette Sales Brochure NOS Original 1978-1982 Speedometer Needle New Speedo Needle USA MADE NOT CHINA <-- contrary to what other vendors say, this needle will not fit a tachometer.... 1968-1982 Corvette T-Top Suitcase Storage Bag Black Canvas 1968-1977 Corvette Door Panel Clip, 2 Clips & 2 Screws |
I'd like the 78 sales brochure, but it says $37 shipping!
check it now... it had the wrong shipping method listed on international... I think I fixed it.
68-77 Corvette Headlamp Switch, Headlight Switch ** W/Vacuum Switch**<-Correct
1968-1971 CORVETTE TEMPERATURE GAUGE CLEARANCE ITEM ONLY. 1975-1977 CORVETTE Power Window Circuit Breaker 1971 CORVETTE RADIATOR SUPPORT SEAL KIT (350 W/PLASTIC SHROUD & ALUM. RADIATOR) 1969 Corvette Spark Plug Wire Set dated 1-Q-69 CLEARANCE ITEM 80 CORVETTE ROCKER PANEL MOLDING SET 14015283 14015284 NOS MOULDING Air Conditioning,AC,Compressor Hose,C3 Corvette,1976Late-77 Early Clearance Item 67 68 69 CORVETTE 427 HOOD EMBLEM CAR ST NEW INCLUDES NUTS. |
Added more items tonight. The quantities of the items are correct and so if the link is good then you can buy it, when we run out it'll close the links out. So if you have any question about it being in stock... if it wasn't it wouldn't be on here. :)
Willcox 80-81 CORVETTE HORN BUTTON EMBLEM CLEARANCE ITEM 77-82 CORVETTE PILLAR POST WEATHERSTRIP OUTER CLIPS - 1 PAIR 69-82 CORVETTE PILLAR POST WEATHERSTRIP INNER CLIPS - 1 PAIR 69-77 CORVETTE ANTENNA NUT FIXED MAST ANTENNA NUT 68-81 CORVETTE POWER WINDOW WIRE CONDUIT - 1 PIECE - 2 REQUIRED - NEW! 63-67 68-79 CORVETTE POWER STEERING PUMP STUD AND NUT KIT "CORRECT" 1973-1977 CORVETTE EXPANSION TANK PUKE TANK 1978-1980 Early Defrost Control Switch, Defrost Switch. 70-75 Corvette Carpet Set 4 spd Clearance item 09 Med Blue loop 68-77 Corvette Headlamp Switch, Headlight Switch ** W/Vacuum Switch** |
Sales pamplet and correct door strikers?
By chance do you have a 1979 sales pamphlet for an L-82 4 speed car? We are also looking for NOS or correct door strikers.
Thanks, Bobo |
Originally Posted by Bobo Greybeard
(Post 1598941120)
Thanks, Bobo |
I ordered a headlight switch today , when I get my e-mail and passwords all straight again there are some other things I'll need from your site !
Thanks all at Willcox! Ray |
Originally Posted by SPCL FX
(Post 1598944680)
