More new stuff today.
56-69 CORVETTE WATER PUMP REBUILD KIT ALSO FITS CAMARO W/SB CLEARANCE ITEM! All the assembly manuals listed below are from our old display, they are new books some are in the plastic, others are not but they are 100 percent as CA shipped them to us years ago. This is the loose leaf design which is no longer being made. If you want them in a CD format I have all of those on my regular site. Assembly Manual 1968 CORVETTE ASSEMBLY NEW CLEARANCE ITEM SEE DETAILS BELOW. Assembly Manual 1972 CORVETTE ASSEMBLY NEW CLEARANCE ITEM SEE DETAILS BELOW. Assembly Manual 1974 CORVETTE ASSEMBLY NEW CLEARANCE ITEM SEE DETAILS BELOW. Assembly Manual 1975 CORVETTE ASSEMBLY NEW CLEARANCE ITEM SEE DETAILS BELOW. |
I'll be adding more today but the 68-71 fuel gauges were deleted by accident so here is the new link.
1968-1971 Corvette Fuel Gauge New Reproduction Clearance Item. |
Received my new headlight switch today and it arrived in perfect condition!
Thanks again ! |
good deal.. I've probably got 20 more... Sadly we had a guy in purchasing that..... as my wife would say... "Liked shopping".. I'll leave it at that for now but we keep finding other stuff everyday where we sell maybe 2 in six months but have 20 in stock. You guys are getting the first notice of these items...
76-77 Carpet Vinyl Strips. Smnoke Door panel carpet set cut pile clearance item
70-77 Carpet Vinyl Strips. Black Door panel carpet set cut pile clearance item 1968 WINDSHIELD HEADER MOLDING BLACK COUPE CLEARANCE ITEM 1968 WINDSHIELD HEADER MOLDING RED COUPE CLEARANCE ITEM 73-75 Corvette Rear Compartment Unit. Dark Blue Pile 3Door CLEARANCE ITEM Corvette Park Brake Console. Light Saddle With Power Windows 70-72 Parking Brake Corvette NEW Power Steering Slave Cylinder Frame Bracket Strap&Bolt Kit 63-82 PR 1973-1979 CORVETTE HOOD DECAL KIT BLACK 63-67 68-82 CORVETTE FRONT LOWER SHOCK MOUNT BOLT KIT 68-74 CORVETTE OUTSIDE MIRROR & HWARE LH 68-74 CORVETTE OUTSIDE MIRROR & HWARE RIGHT HAND SIDE Lots more added today.. :) Willcox |
Just a few more added today... I'm trying to clean house and these items are a great deal. I'd rather you guys get a shot at them first but I can't do it on the site and ebay too... it would cause so much confusion.
So here are today's additions. 70-73 Rear Exhaust Panel With Standard Exhaust New Press-Molded as original This is a Sermershiems press molded panel. 1976 WINDSHIELD HEADER MOLDING AND PILLAR MOLDING SET 3PC IN CORRECT BUCKSKIN This is the original style buckskin vinyl and not the replacement that is available today... we've had these for over 10 years but they are in the correct speckled buckskin not the solid one like you'd get today. 56-62 63-67 68-72 CORVETTE SPARK PLUG HEAT SHIELD SET Willcox |
More stuff added yesterday.
63-81 CORVETTE CLUTCH FORK BOOT NEW ALL WITH MT 1968-1979 Early Corvette Rear Storage Compartment Stainless Steel Hinge Set 3pc 78-82 CORVETTE DASH VENT SIDE DEFLECTOR EA. 1974-1982 CORVETTE NOS DOME LAMP TERMINAL 2 REQ. 8911418 COURTESY LAMP TERMINAL 77-82 Corvette CENTER Dash Vent Deflector NOS GM 336485 in the GM Box 2 req 78-82 Corvette Outer Dash Vent Deflector NOS GM 469048 in the GM Box |
1970-2004 CORVETTE SIDE POST BATTERY DISCONNECT Corvette Correct! Console, Glove Box Door Light Harness Switch W/Bulb 69-77 Lamp 1980 Corvette FRONT NOSE Emblem NEW Reproduction 65-82 Corvette Pass Side RH Rear Brake Caliper Mounting Bracket 65-82 Corvette Drivers Side LH Rear Brake Caliper Mounting Bracket 63-68 Corvette Standard Steering Shock Absorber Dampener Frame Bracket Set |
More stuff added today.
Corvette Door Handle Opening & Lock Control Right Hand Door Opening mechanism then we put up a perfectly good used one here Corvette Door Handle Opening & Lock Control Right Hand Door Opening mechanism 1969 Late 1970-1975 Corvette Convertible Lock Pillar Plastic Wedge CLEARANCE 1977 EARLY CORVETTE ENGINE WIRE HARNESS 1ST SEE NOTES. |
TTT, keep cleaning!
Crap! I needed the black sunvisor with vanity mirror
Okay, today I went through each item we had listed above and removed all items that are gone.
Today I added the following items: 1970-1972 CORVETTE 454 HOOD EMBLEM SET, NEW WITH SPEEDNUTS HOOD NUMBER SET 68-75 Corvette Hardtop Rear Bow Weatherstrip New Clearance USA made. SBC Chevy Performance HEI Distributor Red Cap Super Coil 305 350 400 Small Block 1957-1968 CORVETTE INTAKE GASKET SET S/B ALL CORRECT TABS CLEARANCE ITEM. 68-69 CORVETTE BUMPER GUARD LH CLEARANCE ITEM. 1972-1974 CORVETTE AMP GAUGE CLEARANCE ITEM ONLY. BATTERY GAUGE and our newest product... Temperature Gauge Fuel Gauge and Oil Pressure Gauge Resistor Reproduction 68-76 This resistor will replace the wire wound resistor on any 68-76 gauge. Willcox |
Originally Posted by Willcox Corvette
(Post 1598935955)
Added more items tonight. The quantities of the items are correct and so if the link is good then you can buy it, when we run out it'll close the links out. So if you have any question about it being in stock... if it wasn't it wouldn't be on here. :)
Willcox 80-81 CORVETTE HORN BUTTON EMBLEM CLEARANCE ITEM 77-82 CORVETTE PILLAR POST WEATHERSTRIP OUTER CLIPS - 1 PAIR 69-82 CORVETTE PILLAR POST WEATHERSTRIP INNER CLIPS - 1 PAIR 69-77 CORVETTE ANTENNA NUT FIXED MAST ANTENNA NUT 68-81 CORVETTE POWER WINDOW WIRE CONDUIT - 1 PIECE - 2 REQUIRED - NEW! 63-67 68-79 CORVETTE POWER STEERING PUMP STUD AND NUT KIT "CORRECT" 1973-1977 CORVETTE EXPANSION TANK PUKE TANK 1978-1980 Early Defrost Control Switch, Defrost Switch. 70-75 Corvette Carpet Set 4 spd Clearance item 09 Med Blue loop 68-77 Corvette Headlamp Switch, Headlight Switch ** W/Vacuum Switch** Does the 70-75 carpet set include covering the rear deck, wheel wells and storage compartment doors? Thanks |
Originally Posted by nwav8tor
(Post 1599273201)
Thanks Willcox |
This will not make your monthly sales quota, but I used the link to buy 2 of the battery post disconnects. I have been wanting to get some of these for a while to make it easier to connect my battery tender, and the clearance price was good. Thanks:thumbs:
Hi Ernie,
We spoke a week ago about a 1968 coupe black 80/20 loop carpet water fall only section while you were away. Any single piece avail? Thank you for all you do to keep us moving. Marshal |
I won't be back until Monday.
Ok thanks Ernie
