-   C3 General (https://www.corvetteforum.com/forums/c3-general-119/)
-   -   Ignition shielding. (https://www.corvetteforum.com/forums/c3-general/4241278-ignition-shielding.html)
540 vette 02-11-2019 07:20 PM
Ignition shielding.
I have a 72 with a big block, what do I need for the ignition shielding and does anyone sell a full kit.
Mooser 02-11-2019 07:25 PM
The top cover
Two standoffs (bolt to the intake)
Two rubber inserts for the standoffs that hold the ignition wires
There are also the shields around the spark plugs themselves, not sure if that's really ignition shield or heat shielding
The wires also had a braided sleeve on them that was grounded
I think that's it of the BB
Never seen it as a kit
M
7T1vette 02-11-2019 10:42 PM
The reason for ignition shielding is strictly to prevent ignition noise from getting into the sound being produced by your radio. If you have a more modern radio which has better noise rejection capabilities than the old Delco units, you may not even need shielding.
540 vette 02-12-2019 03:38 AM
It came with the car so I want to add it to make it appear more stock. I am also adding a Sniper fuel injection and they have trouble with RF signals from the plug wires and the computer. So adding the shield may help.
3X2 02-12-2019 07:27 AM
Paragon Corvette sells what you need. Looks like part number 3295K in their catalog. You may want to consider their 3293K for 68-70 since it has the box that goes around the distributor and coil.
