Will 7inch Motorized Face of Pioneer work With Metra Bezel
Hello....
I have a 99 C5 and want to upgrade the Head Unit. I have my eye on the Pioneer AVH-2300NEX with a MOTORIZED Face. I also have plans to buy the entire Metra Bezel Kit with the interface module so I can continue to use the factory Bose Speakers with the Pioneer: MY CONCERN is whether or not the Pioneer AVH-2300NEX with a MOTORIZED Face will have enough space to operate correctly. Is the Opening large enough for a 7 Inch Motorized Face ? Just a FYI..... In case you are wondering why I chose this Head Unit, it is because of price and features so I can use my Android Phone (Samsung Galaxy Note 4) and get Navigation and Bluetooth connectivity for $300. My Girlfriend said she will allow me $300 for my birthday present. Do you guys know of a better 7 Inch head unit I should consider with Navigation from my Android phone for $300 ? . |
Ttt
I just completed an install on a Sony XAV-712HD, it has a 7" motorized face. I bought the Metra 95-3304 Kit and the face plate would not operate correctly, once it opened for a CD or DVD when it went to close it would just continue to open and close over and over. I searched YouTube and found a video where the guy took a razor knife and slowly scrapped the bottom opening to make it a litter bigger. I did what he said and everything works correctly. You cannot even see that i had made an adjustment.
video
here is the video.
Hmmm, glad I saw this as I was just about to order one because of the following problem I had trying to install my Pioneer Avic-8400 Nex.
After waiting a month for my install appointment to finally arrive, my installer ran into a few problems. The plastic brackets that came with the Vettenuts bezel cracked when he screwed them onto the HU rendering them useless. Btw, there were no instructions on how to assemble the brackets to the HU, which seemed easy enough to do, but the brackets didn't fit the way you would logically expect them to fit. Half way thru the install, the installer test fit the HU to the bezel only to discover that, although it appeared to fit great, the bottom of the bezel didn't clear the bottom of the HU enough to allow the face plate to open to get to the DVD or memory card slot. He said he's installed a couple Metra bezel in C5's and never had this problem. I wasn't about to start shaving any material off the bezel in case it still wouldn't fit and then I wouldn't be able to return it. Wasted 8hrs today and very disappointed. Unfortunately, his first available appointment isn't until March 8th so we can try it again... |
When I installed my Kenwood DD in my 03 using a Vettenuts bezel I had a similar issue with the motorized face.
Using a razor blade or knife can easily go bad. One slip can easily cut too deep. That is why I just used a sandpaper block with fine sandpaper which is more accurate and easier IMO. Took a few trial fits but worked out just fine for my install. BTW, my plastic Vettenuts brackets also broke as I suspected they would. I ended up making my own brackets from stock metal angle brackets like used in construction. Not pretty but will never be seen and are very strong. https://cimg2.ibsrv.net/gimg/www.cor...06b1f7bec5.jpg |
Finally got my Pioneer HU installed. I followed the directions demonstrated in the 5 Star video and it was very easy to shave material from the bezel using a sharp utility knife. It looks and works great now, even my installer was impressed and wanted to know what special tool I used to trim it. When I showed him, he was surprised...
I installed a pioneer avid 8200 next with a metra kit and moulding and no issues.
