A&A secondary drive question
I’ve been told by a few people it squeals on cold start up and goes away once warm.
which it does but damn it’s annoying lol is there a way to keep it from squealing? |
I have Cartek flip drive and it was squeal while after cold start. I use industrial belt grip spray and its not squeal after that. I drive last summer about 3000km and use spray only one time. In my case it was easy and cheap sollution to annoying problem.
Mine only did that because the alternator/power steering belt was too long. I went one size down and haven't had an issue since.
I'm running the same setup without any issues, although it was installed at A&A. Quiet cold starts for almost 2 years now.
Originally Posted by Vette97sc
(Post 1598875574)
Originally Posted by Patriot Six
(Post 1598875902)
mine does not squeal hot or cold. If you are still using green belts, they glaze over and squeal. Get rid of it and go to the RPM belts.
Originally Posted by Jason.
(Post 1598875562)
(Post 1598877376)
I’ll look into that spray any special brand or naw?
im using the belts that a&a provides hmmm |
(Post 1598877376)
Mine squealed from day 1 on cold starts. Kept getting worse and worse little by little. Running all belts that A&A sent for the secondary and the green hd belt for blower.
Last weekend, I discovered the top bolt that holds bracket that the jack-shaft is on had backed out. Took it apart, re-positioned it back correctly, put new 4-rib belt on and it didn't squeal on cold start. But I have only started it twice since then. Anxious to see if that was the problem. |
If you don't have the newer design, as the belts wear and stretch, all the direct drives in my experience start to squeal. Means the belt is too loose and needs a bit more tension and to be replaced. I would get 5-6k out of a belt before squealing and needing a new one before I went to the ECS setup.
I’m using gates belts not green
(Post 1598879188)
It came with a 37" belt and I am now using a 36.5" belt (K080365).
Originally Posted by da6speed
(Post 1598885371)
Originally Posted by Unreal
(Post 1598885605)
but was my first time installing it |
Only time mine ever made noise when starting was from the A/C belt when loose. Have you tried with and without AC on ?
I have had the same problem for the last 2 years ever since system was installed. I've changed to a shorter belt, I've tried the grip spray, I've changed the tensioner. I've adjusted belt loosening and tightening it. When I take accessory belt off and start it no squeal at all. As soon as I put it back on it squeals. So I believe it's in the jackshaft area pulley, bearings something. I've talked to Andy and Josh over two yrs several times and explained my thoughts on everything. I sent them pics and they told me tighten it more. It did nothing.
When speaking with Andy last week he really didnt know what else to tell me. Said it could be a number of things but without seeing it he wouldn't know. So my next and final step is to change the jackshaft pulley assembly. Wish me luck guys. I've hated driving this thing for the past two yrs because if this. Hopefully this fixes it. |
Originally Posted by 07blkvette
(Post 1599181985)
I might be the lucky one then.almost 2years since my install on my setup.no squiling whatsoever still on the green belt supplied by A&A.stepping down to a 3.8 pulley this month.4.0 is getting boring.lol.I think it all come down to your alignment and belt tension.
Blower side of it has very little to nothing to do with the DD issues.
Just installed mine this past weekend and haven’t had the first squeal out of it yet. Fingers crossed
I’ve had mine for nearly two years. The only time I had any squeal was before the original accessory belt was replaced with a smaller one and just recently when my power steering reservoir was leaking fluid onto the jackshaft and accessory belts. Good luck getting it sorted out.
It took about 2 weeks for mine to start making noise. It squeals when cold (bad). Switched to the 060365 belt. Did the trick for a short time. It squeals a bit on start up then goes away. I found a 060360 belt that I may try.
